Home > eBay & Bargain Spots > Opie oils |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Limited time offer from Opie Oils ... code GIVE15,
23rd Jun 2019 8:21am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Castrol Edge Titanium and a Mahle oil filter for my TD6 = £67.50 delivered.
23rd Jun 2019 12:12pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
This oil ok for 2012 westie ? https://applications.castrol.com/oilselect...2010-2012) |
29th Jun 2019 8:09pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Oil debates are always fun and full of options and little facts.
30th Jun 2019 7:47am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 737 |
i worked for a mob that had a mob of trucks, all petrol.
30th Jun 2019 8:59am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
The german site carpartsforless.co.uk - where I got my last year's AF-L oil - is no longer doing the AF-L
30th Jun 2019 9:15am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Sorry, you are wrong there. Although new to FFRR's I have recently come from a VW T5 forum. It is a known fact (on there anyway) that using the incorrect oil in early T5's will result in premature camshaft wear & the incorrect oil in the later ones will result in issues with the DPF. Why do you think that a cheapskate outfit like VW produce &/or source so many different oils ? 2003 Range Rover Vogue TD6 |
30th Jun 2019 10:07am |
I did qualify my comment with the correct type and spec... what you are talking about is high zinc additive like ZDDP for high pressure wear points like tap pets, buckets, shims and high pressure fuel pump etc.
30th Jun 2019 11:16am |
A simple yes or no would help |
30th Jun 2019 11:20am |
Yes, Castrol recommend that oil, it meets the spec and type of use ie suitable for Diesel engines. |
30th Jun 2019 11:28am |
My apologies - I read your post a little too quickly whilst getting GBH of the ear-holes from the domestic authority. 2003 Range Rover Vogue TD6 |
30th Jun 2019 11:44am |
Thank you ur20v. |
30th Jun 2019 1:15pm |
No problem to both Brian’s |
30th Jun 2019 5:37pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 730 |
Even if Castrol do recommend their oil I don't get why anyone would choose to NOT use the oil recommended by Landrover.
30th Jun 2019 6:56pm |
