![]() | Home > In Car Electronics (L322) > Harmon Kardon Logic 7HD |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
If it's a Westminster it should have the HD 1200w system.
Bryanrambles Member Since: 18 Feb 2019 Location: London Posts: 33 ![]() ![]() ![]() |
Have checked all the settings and still no joy.
CD or ipod input?
Have tried CD, iPod and USB. |
With my HD the speakers are like air pumps, one time the door speaker was making my jeans flap with the bass.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Turn the logic 7 surround off. I had same issue with mine till I did that. I only use it for films. 2011 Range Rover Vogue SE 4.4 TDV8
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I don't listen to the radio but mine is much richer playing from a USB stick with Logic 7 enabled than when not. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I thought the sub had gone on mine but had it checked and it was 'ok'. No oomph at low to medium volume. Motorway noise drowns out the bass. Only solution is to wind up the volume, then it's fine |
Thanks for all of the responses. Will take a look.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
You are more than welcome to try mine out if you in South West London anytime to compare Current Fleet:-
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I did a little reading around the HK logic because I didn't think my sub was working.
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
We did exactly the same thing just this afternoon!
With the view of having an open mind, I shall experiment with my Logic 7 back on.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Did you experiment? How did you get on?
