![]() | Home > Technical (L322) > Question about radar cruise control |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I was just wondering - when I set the cruise control, the car slows when approaching slower moving cars. Do the brake lights come on to warn following drivers that I’m slowing? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
ACC [adaptive cruise control] normally uses the engine and gears to slow down but it needs sudden de-acceleration then the brakes are used ... |
I’ve changed mine to the jag profile using the IID tool and it now stops the car completely. I did wonder if I was going to be hit from behind! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
As standard I don’t think the brake lights come on, as it’s only easing off the throttle.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
It really does brake for you MJD !
I’ve never had that happen. Don’t use it much though. 2011 Range Rover Vogue SE 4.4 TDV8
