Home > Technical (L322) > Tow bar rear chassis bolts???
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
My 2004 l322 is in bits on the drive as I'm in the process of fitting a witter tow bar. Unfortunately I have to use the existing chassis bolts, but they are not there. Anyone know the part number for these or alternatively the bolt dia and length. Looks like the job is not getting finished today!!! RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #514452 6th May 2019 1:54pm
Weegie
DIN 960 hexagon screw M14x1.5 fine thread with shank steel 50-160 mm. I got mine from this guy on the Bay:
https://www.ebay.co.uk/usr/schrauben.exper...2749.l2754 John
GAP iiD BT-Sold
Post #514460 6th May 2019 3:28pm
NVB
Thanks Weegie. Having had another look at them,there appears to be two different sized bolts. The front ones are fatter and the thread is on the surface, while the back ones look thinner with very deepset thread. The thread does look fine.
M14 might be ok for the back fixings, but a course pitched M16 bolt slides in and out of the threads on the front holes, so this must be something else. RR History
Post #514466 6th May 2019 4:23pm
Weegie
The ones I got were for the rearmost fitting. They were for a Westfalia bar. The forward ones may be different as you say. I see you have a request in to Dan. Hopefully he can help.
The main thing to be sure of is the shear strength (DIN No.) as they need to be within the torque range required. IIRC 160nm but needs checking.
Good luck with it. John
GAP iiD BT-Sold
Post #514470 6th May 2019 4:57pm
NVB
Thanks again. I have given up on the job for today so will see what Dan comes up with. It will be easier just to get the right bolts from LR and to hell with the cost Very Happy I want t do it right being such a safety critical issue. RR History
Post #514472 6th May 2019 5:37pm
