Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 684 |
Oh and the issues have never gotten worse in 5 months and 6000 miles |
30th Apr 2019 4:55pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Well, you seem to have exhausted the enigine as a problem. Maybe, as suggested earlier, its a trans issue.
30th Apr 2019 5:28pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
When you say reset adaptions, do you mean within the IID tool?
2nd May 2019 5:37pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Drive car in S mode for 3~4 days, it will help with D mode adaptacions. 2012 TDV8 Black Edition
3rd May 2019 7:29am |
I will give ZF a ring first thing Tuesday morning, see if they can point me in the direction of my closest ZF approved agent.
5th May 2019 7:45pm |
RR booked in to have the gearbox checked on Thursday. |
7th May 2019 9:01am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2519 |
I suspect that the drop in fuel pressure is significant. Do you know where the pressure sensor is located - in the end of a rail or at the pump? |
7th May 2019 9:07am |
I believe its in the end of the rail Graeme.
7th May 2019 9:11am |
The fuel pressure sensor is indeed in the fuel rail.
7th May 2019 10:37am |
The WSM for the 3.6 in the RRS states that pressure is adjusted depending on engine rpm and load so the lowered pressure but no DTCs that you noted is likely to be due to the reduced load rather than causing it. |
7th May 2019 10:39am |
Ah i see so the reduced pressure/pressure drop is normal as the load on the engine reduces? |
7th May 2019 11:29am |
But why did the engine load drop if you were still accelerating. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
7th May 2019 1:55pm |
This is what i was just wondering.
7th May 2019 3:37pm |
Clutch packs ???? I think the transmission check could be telling. Im intrigued. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
7th May 2019 4:02pm |
