Home > My Range Rover > range rover with problems
Page 15 of 18 <123 ... 1415 161718>
Essex1959
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
I am currently at the stage now where i am ready to time my m62 engine after a total rebuild which i started back in January and awaiting delivery of the GAS tools, I have followed this topic and have learned lots of valuable information so thanks too
Post #513279 26th Apr 2019 12:30pm
holidaychicken
i was just thinking that you are in Essex so just across the water from me and realised you are in waleshire .. Very Happy
Post #513320 26th Apr 2019 7:53pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Essex1959 wrote:
Glad you are sorted Thumbs Up I have big hands and managed to screw the nylon wingnut on with the filter box removed. Your hands must be like shovels Laughing
Laughing Laughing
my hands and Arfur Rites are big mates RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #513336 27th Apr 2019 2:17am
Essex1959
Sheep Thumbs Up
Post #513341 27th Apr 2019 6:28am
Essex1959
knares wrote:
Laughing Laughing
Mr. Green
Post #513342 27th Apr 2019 6:29am
knares
the guy over the road is a mechanic, he came over and we spent some time trying to find out why it has a miss, it seems to only be missing on idle, once you touch the accelerator the miss seams to go.
we couldn't find any reason for the miss.
i am thinking it might be a manifold gasket leak
i have been taking it around the block for a bit of a run, trying to get the feel of it, when i leave the three amigos are on, after about a KM they go off, a KM later they come on again
it says on the dash, the air suspension is not working but i can hear the compressor going some times and it looks ok
i want to get it insured before i take it far and i keep forgetting to do that during the day
i will have to get some prices RR 2005 4.4 petrol
Post #513557 29th Apr 2019 1:13pm
holidaychicken
If your timing is out a bit then that will give you a miss on idle . The air suspension will try and fill the reservoir but if the pressure isn’t increasing as expected it will throw a fault. You said your battery is ok didn’t you?
You should have other fault codes stored if your diagnostics are finding them.
Post #513624 30th Apr 2019 1:11am
knares
yes, i have other faults
just went up the road,110km/h thats the max here.
the engine is fine when accelerating or decelerating but when you just touch the pedal to maintain the speed it misses badly, you would think you had square wheels
A/V off
engine
1/4 electric thermostat fault
2/4 camshaft control bank 1
3/4 multiple misfire fault
4/4 misfire detected cyl 1
ABS
0x0020 front right wheel speed sensor open circuit 1/3
0x0061 steering angle sensor initialisation 2/3
0x005a temporary system deactivation 3/3
AIR SUSPENSION
CAN bus fault 1/1
apart from the square wheels, it goes great RR 2005 4.4 petrol
Post #513791 1st May 2019 4:53am
knares
how did you go RR 2005 4.4 petrol
Post #514158 4th May 2019 12:32am
Essex1959
Long story short whilst awaiting the GAS tools that should be here next week i pushed on slowly rebuilding a 2nd engine i purchased with a view on keeping it as a just in case i need it scenario. So all i have to do now is time up the newly built engine i have in my car now (not looking forward to that) and hopefully get to drive it soon something that i have not done since purchase last December. How about yours any luck ? @holidaychicken has gone quiet too so i guess something broke on his Rolling Eyes
Post #514166 4th May 2019 6:20am
knares
haven't done any thing, insured it, (we dont have to insure here,) just take it for a drive, its still missing badly just as i touch the pedal
trying to get the hang of it, so many buttons to press.
the valance on the front seat is broken, $480 from LR, $250 on ebay, buts thats dear.
i will fit a new fuel filter and change the rest of the plugs next, not that i think that will fix any thing but i am sure they are dew
the three amigos go on and off at will
some time ago i enquired about the price of tires, the cheapest was about $350
i just got one fitted and balanced, $150, i will get the spare done, then i can put the spare in and i will be legal RR 2005 4.4 petrol
Post #514168 4th May 2019 6:47am
knares
before i pulled this engine to pieces, it started immediately and ran, no problem.
since its back together it starts ok then stalls.
it will do this several times before it runs.
this is without using the accelerator
i get the feeling it needs choke
i am wondering if i have not connected something some where
any ideas
thanks RR 2005 4.4 petrol
Post #517584 6th Jun 2019 7:18am
knares
ESSEX1959
how are you going with your motor RR 2005 4.4 petrol
Post #517585 6th Jun 2019 7:20am
Sandy Choda
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Try driving without the Air flow meter plugged in. I've had it before on BMW engines and it drives like a carb'd engine.
Also if i read it right, 3 amigos and steering angle sensor fault. After having disconnected the battery you need to start the car with the steering wheel in centre, then go from lock to lock in both directions. This should re initialise the angle sensor and tell it which way its pointing.
Post #517593 6th Jun 2019 11:08am
Essex1959
any ideas
thanks
Hey there all good here and got my motor running after the costly engine rebuild only finished it last week as busy doing other things like working and making some money Very Happy . I am about to send it in for it's annual MOT as soon as i have fitted a new suspension bush or bushes, then off on a road trip to Romania fishing for a couple of weeks 3,000 miles round trip that will be exciting and looking forward to it. With reference to your problem it could well be a overlooked lead left unplugged although i would have thought it would show something on diagnostics ? did you have any joy with the 3 amigos and remember you were awaiting on a wheel sensor delivery i attach some pics of mine
Post #517601 6th Jun 2019 1:42pm
