![]() | Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
i was just thinking that you are in Essex so just across the water from me and realised you are in waleshire .. |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 780 ![]() ![]() ![]() |
![]() ![]() my hands and Arfur Rites are big mates RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Essex1959 Member Since: 21 Feb 2019 Location: Wales Posts: 20 ![]() ![]() ![]() |
the guy over the road is a mechanic, he came over and we spent some time trying to find out why it has a miss, it seems to only be missing on idle, once you touch the accelerator the miss seams to go.
If your timing is out a bit then that will give you a miss on idle . The air suspension will try and fill the reservoir but if the pressure isn’t increasing as expected it will throw a fault. You said your battery is ok didn’t you?
yes, i have other faults
how did you go RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Long story short whilst awaiting the GAS tools that should be here next week i pushed on slowly rebuilding a 2nd engine i purchased with a view on keeping it as a just in case i need it scenario. So all i have to do now is time up the newly built engine i have in my car now (not looking forward to that) and hopefully get to drive it soon something that i have not done since purchase last December. How about yours any luck ? @holidaychicken has gone quiet too so i guess something broke on his |
haven't done any thing, insured it, (we dont have to insure here,) just take it for a drive, its still missing badly just as i touch the pedal
before i pulled this engine to pieces, it started immediately and ran, no problem.
ESSEX1959
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 ![]() ![]() ![]() |
Try driving without the Air flow meter plugged in. I've had it before on BMW engines and it drives like a carb'd engine.
Hey there all good here and got my motor running after the costly engine rebuild only finished it last week as busy doing other things like working and making some money ![]()
