![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
After a bank holiday Monday of rolling around on the floor swearing the short PCV hose is now firmly attached with 2 hose clamps.
Right, car back with a report from the specialist.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Are you able to read the live values of the EGR valves?
Hi Mikey,
An early start this morning,
I'd be inclined to remove the EGR blanks. The PCM expects to see a drop in MAF values when the EGR's open...
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
This is one of the strangest problems ever.
This was the trace from the one I had in
I am sure the EGRs can be ruled out of this Mikey as they are phsyically blanked and unable to recirculate into the intake as well as being mapped out in the cars software.
So, you had no issues prior to remap and blanking
I had the check engine light on for an EGR issue, had them blanked and mapped out.
Quantum is a decent map. I and a few others on here have their map without issues so it probably isn"t your issue. I wasn't sure you knew the history of it which is why it was suggested.
Have you checked MAF sensor values.
