![]() | Home > Maintenance & Mods (L322) > Bottle Jack or Trolley Jack? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
I stick by my earlier advice
The factory lack is ![]() |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
I asked because i am thinking of buying a trolley jack to lift the RR and then put Axle stands.
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
this is the one i have https://www.sgs-engineering.com/tj3lp-low-...olley-jack
cheers thanks |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
I've gone for this kit - jack goes up to 520mm so should be plenty and over specced 6 tonne (each) axle stands
can you lift the rear Subframe between the exhausts with that one? how big is the pad?
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Its no simple answer I am just sure I am never going to use the scissor jack again! BLOODY SCARY!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
I also ditch the locking wheel nuts for standard ones. They will round and fail. I only just got one of mine off - it was well chewed up |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
For this reason, I have a set of both 22mm and 23mm hex sockets! 2010 RR SC 2007 RR SC |
Sorry just got round to measuring the pad - it's 135mm diameter. Regarding the SGS Kit - I haven't used it yet but having just taken it all out of the box it all looks to be very heavy duty kit. The trolley jack is an absolute monster. First purchase from them and so far I'm impressed. I think I'll get hold of a Disco bottle jack for suspension lifts/wheel changes however I'm happier with the trolley jack for high lifting than a tall bottle jack. I've also got the 22mm and 23mm sockets - that's good advice. |
