Home > Maintenance & Mods (L322) > Bottle Jack or Trolley Jack? |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Trying to decide between the Sprinter bottle jack and a trolley jack. Either way I'll also get some Axel stands but not sure whether to go for the convenience of the smaller bottle jack or a sturdy trolley jack like the one below.
21st Apr 2019 3:41pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
The sprinter bottle jack is used by folk who dont trust the standard scissor jack at the roadside for an emergency wheel change. If you are after a jack to raise the car to work on then a trolley jack and axle stands is the way to go.
21st Apr 2019 3:59pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7957 |
I just bought this jack from SGS and used out for the first time today to swap to my summer wheels / tyres - it did the job very well
21st Apr 2019 6:46pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Wot he said đŸ‘† Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
21st Apr 2019 6:48pm |
I lift it under the suspension with a trolley jack or a Disco 2 red bottle jack with a U shaped saddle.
21st Apr 2019 6:50pm |
Thanks all.
21st Apr 2019 9:53pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
with a jack under the suspension arm your fine for wheel changes - as said it only needs lifting a couple if inches.
22nd Apr 2019 8:12am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
WB,
22nd Apr 2019 8:32am |
Nino_nino, thanks for those photos, I'd forgotten how short the double piston Discovery 2 jack is!
22nd Apr 2019 9:41am |
Those red jacks are perfect for changing a wheel and much safer than the scissor jack.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
22nd Apr 2019 1:04pm |
Tyre fitters, and me, never use jacking points. Always under a suspension arm or subframe. A lot less lift needed so much more stable.
22nd Apr 2019 1:08pm |
Thanks guys, think I'm going to go with one of the Disco jacks for now and maybe invest in a trolley jack later.
22nd Apr 2019 9:04pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
+1 for the sprinter jack.
22nd Apr 2019 9:53pm |
WB, in the normal height if you are lifting just wheels and offroad height if lifting using jacking points. I use piece of 4"x4" under jack when lifting using jacking points. everything fits nicely in the storage bin in the beck.
23rd Apr 2019 8:23am |
