Home > Technical (L322) > L322 8HP 4.4TDV8 Gearbox Failure |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Sorry to hear about your trouble. Not sure about the model numbering. I thought they all had the 8HP70.
8th Apr 2019 11:58pm |
OO__OO Member Since: 15 May 2014 Location: Manchester Posts: 18 |
No towbar or evidence of one. Sold by Hatfields Liverpool, Land Rover main agents. Last 2 services were by them but no mention of gearbox. Last service at 96k. |
9th Apr 2019 12:20am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2463 |
A different gearbox part number was introduced starting with VIN BA347155 but I can't believe that an 8HP45 was ever fitted. Microcat describes the boxes as 8HP70 from the outset which I expect to be true.
9th Apr 2019 4:51am |
Only engine code is for EGR temp sensor which will not clear. Trans came up with P0741 Torque converter clutch solenoid - circuit performance or stuck off.
9th Apr 2019 6:53pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
The EGR fault code is probably this. Very common. I have it and it never clears. Instantly comes back. Will be getting it changed out at Rovertune in Reading soon
9th Apr 2019 7:08pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3762 |
You could Google ... Tameside Transmissions.... It might be worth a phone call.
9th Apr 2019 8:54pm |
Just a thought on this OO__OO, you say oil change, but given your symptoms a power flush may be better.
10th Apr 2019 10:31am |
LR's "sealed for life" means "sealed for life of any LR warranty that expire at 10years".
10th Apr 2019 11:06am |
My mistake! The gearbox is an 8HP70 !!! I read the sticker with a mirror & my eyesight is not always so good. I checked again & it is embossed on the side of the casing 8HP70 . Sticker reads BH42 7000 AE.
10th Apr 2019 7:23pm |
Might need an auto tranny specialist.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th Apr 2019 7:32pm |
Trans is now fixed. Bought a second hand one with torque converter for £650+vat. Reputedly only done 32k miles.
27th Apr 2019 10:23pm |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 138 |
Nice glad you got it sorted
28th Apr 2019 12:01am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Glad you found a relatively cheap fix , makes that a very cheap 4.4 2015 4.4 AB
28th Apr 2019 9:59am |
OO-00, great result
28th Apr 2019 11:13am |
