Home > Technical (L322) > L322 8HP 4.4TDV8 Gearbox Failure
OO__OO
Telly addict, no didn't do it myself, paid a local garage whom I give work to. So total cost was £11500+ £125+ £235+£360+£780 = £13,000. Plus road tax + reg. plate transfer etc. etc.
Just need to sort the drivers heated/cooled seat now!
Austin Champ was amazing vehicle, Rolls Royce engine as said. Everything waterproofed, including the switches & gauges & a lever for reverse so it could go backwards as fast as forwards if you had the nerve:- I didn't! Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Lightweight L/R I converted to Ford 3.0 V6
Classic RR 2 door with 200TDi - written off!
Classic RR 4 door V8 - changed to 200TDi from above
Lada Niva - Little off-road toy
Disco 300 TDi Auto - Thirsty
Classic RR Overfinch 5.7 - Very thirsty
Disco II TD5 with off road kit
Grand Cherokee 4.0
2002 L322 4.4 V8 on LPG
2011 L322 4.4TDV8 SE
1943 Ford GPW
Post #513505 29th Apr 2019 12:50am
There are a few threads running on here about the ducting splitting on the top/backrest peltier motor sir... That seems to be the favourite issue stopping the seat heat/cooler working correctly... Thumbs Up
Post #513527 29th Apr 2019 10:29am
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
i repaired my seat cooler / heater . i ordered off Ebay a Pelitor unit from America DU5Z-19N550-D . same item as a range rover but in a different shape . same size pelitor and transfered it to the range rover sead . £50
quite a few american cars use this tupe of unit .
still working fine .
Hope this hjelps.
Post #570178 18th Oct 2020 4:39am
OO__OO
Thanks Landyandy, I'll look into the peltier though I'm sure I've seen a write up somewhere of someone doing the same thing without success. It required a bit of rewiring as well.
RE vibration at speed, I forgot to mention this was caused by a rear caliper sticking on & upsetting the electronics somehow. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Grand Cherokee 4.0
1943 Ford GPW
Post #570218 18th Oct 2020 3:21pm
GGDR
Landyandy1765 could you post more details of your seat repair and part here pls:
https://www.fullfatrr.com/forum/topic44946...at+mustang
Several of us have tried alternate peltier units without success.
So finding one that does work is a significant find. Thumbs Up
. Cheers, Greg
Post #570220 18th Oct 2020 4:04pm
Landyandy1765
i have some pics and the peletor unit is the same just in a different shaped housing . very easy to sort out . the hardest thing is the removal of the seat and stripping it . mines been working fine now for 12 months. ill post the seat pics and the units for you to see .
Cheers andy
Post #570236 18th Oct 2020 6:16pm
OO__OO
Just an update, the gearbox is still fine.
I fixed the heated / cooled seat with one of these:-
https://www.ebay.co.uk/itm/Peltier-element...1438.l2649
Fitted perfectly & still working though it's only been in a couple of weeks. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Grand Cherokee 4.0
1943 Ford GPW
Post #578120 2nd Jan 2021 3:17pm
