Home > Technical (L322) > Gearbox service 2011 4.4tdv8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
not sure but I did three complete changes just from the sump drain with a day or a long drive between. That way you have full fluid change. Changed the sump (filter) after the second one.
1st Jan 2021 3:39pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1765 |
3 drain and refills is not a full fluid change... |
1st Jan 2021 6:15pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
Where abouts are you |
1st Jan 2021 6:50pm |
Fair enough Mikey
1st Jan 2021 8:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Do yourself a favour and drive to Dundee and let Mikey at MMP do it for you.
1st Jan 2021 9:17pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Just googled 'Shetland to Dundee'..................14hrs Holy Moly.
2nd Jan 2021 8:54am |
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 |
The Shetland Isles |
2nd Jan 2021 11:33am |
Thanks, I might be coming down to the mainland this year, any idea how much they charge for a gearbox flush/service? |
2nd Jan 2021 11:35am |
Tell me about it? 14 hours on the ferry just to get to Aberdeen! Don't mind tackling it myself, but as I said in the original post, does anyone know which pipe is the return from the cooler, top or bottom and is this the easiest/best way to do a self flush? Also what kit is the best? |
2nd Jan 2021 11:40am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
PM Mikey and ask him. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
2nd Jan 2021 11:45am |
