Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Go back to basics as there are no codes, get a compression test done, if a foreign object bent or damaged valves or their seats or rings etc. lack of compression would give a lazy throttle and performance unit the turbos ramp up enough boost to mask the lack of compression |
24th Mar 2019 1:07pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Did you use a genuine LR fuel filter as some after market ones have been known to cause issues? Current 2007 TDV8 Vogue Buckingham Blue |
24th Mar 2019 2:05pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2497 |
Maybe your mechanic was on the money with the other turbo not working properly, but with sticky vanes rather than a sticky actuator linkage. However I still wouldn't expect such a lack of low down performance then a dramatic increase at a particular higher rpm. |
24th Mar 2019 7:35pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Maybe try a genuine fuel filter (if an after market one was fitted), but this is starting to sound like a tin brain to me. You mentioned earlier that you’d had the EGRs blanked and re mapped. Are you able to have this rechecked?
24th Mar 2019 10:23pm |
The vanes are moved to increase turbo speed when exhaust gas flow is low then re-angled to have less effect as exhaust gas flow increases. |
24th Mar 2019 11:03pm |
One other thing.
24th Mar 2019 11:12pm |
I’m wondering if the vanes are stuck in the full load position, so at low load the turbo is unable to spool up, but I’d assume there’s be some alarms to suggest a disturbance in the force.
25th Mar 2019 1:12am |
Have the MAF live values been compared? If the left turbo is performing poorly at low engine revs then the MAFs would read differently. The MAP sensors would be pretty much identical if the I/C is a combined unit rather than have a separate section for each turbo.
25th Mar 2019 3:38am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 678 |
Hi Graeme,
25th Mar 2019 5:20pm |
I would expect the actuator not to move its full swing if the vanes were stuck and therefore expect a fault to be recorded unless the connection to the vane mechanism was damaged allowing the actuator to move as expected. However it would be a real co-incidence for such damage to occur at the same time as the split hose.
25th Mar 2019 8:21pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
It is my understanding that on the 3.6 TDV8 the two banks are fed by effectively separate induction systems with only minimal connection between them. There is no truly common induction plenum. Which is why the system checks correlation between boost pressure delivered and boost pressure expected on each bank and can isolate each one in error codes.
25th Mar 2019 10:21pm |
Maybe we are focusing too much on the engine? Might there be a gearbox-related aspect? Could the fluctuating idle be TC related and the lack of acceleration be a problem with the comms between the gearbox and ECU? Gearbox problems wouldn't show up as error codes.
25th Mar 2019 10:32pm |
Nick, that’s how I’ve interpreted it as well.
25th Mar 2019 10:59pm |
Nick,
26th Mar 2019 10:13am |
