Home > Technical (L322) > Just stopped
mudknight
2003 Range Rover Vogue Td6 Java Black
Just stopped
Hi, 2003 td6 , traveling on M6 doing around 60mph towing , suddenly engine stopped , Got on hard shoulder , just turning over but not firing , Got recovered. Anyone have any ideas please ?
Post #509525 22nd Mar 2019 11:05am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Any warning messages on the dash, if not I think you will need to get some diagnostics. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #509526 22nd Mar 2019 11:11am
mudknight
I can't read anything on the dash as it's too piculated.
Post #509529 22nd Mar 2019 11:21am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Fuel pump maybe? If it's turning over but not firing. There is a secondary pump under a hatch towards the back of the passenger side, if you open the hatch is the pump making any noise? Might be worth an "attitude adjustment" with a hammer if you can't hear anything, (maybe check the fuses first!)
Good luck! Formerly happymadison1978
Post #509534 22nd Mar 2019 12:10pm
fuel pump knackered???
Post #509535 22nd Mar 2019 12:10pm
mudknight
I've fuses and swooped relay , will check if I can hear pumps next . Sounds big money if it's the pump.
Post #509537 22nd Mar 2019 12:37pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
It's not too pricey, and there are cheap options but in my experience they don't run at all quietly. Having said that you can get one for £30 if money is tight and then swap out in a couple of months.
Get the ignition to II and get under the passenger side rear, you should be able to hear the pump whirring away. If not, give the whole case a few smacks with something hard. That kept me going for 6 months until I fixed it, but it's a really simple job
Post #509555 22nd Mar 2019 2:28pm
mudknight
I'm usually good at using the hitting stick , will give it a go . Cheers
Post #509557 22nd Mar 2019 2:53pm
