![]() | Home > Technical (L322) > Just stopped |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Any warning messages on the dash, if not I think you will need to get some diagnostics. 2007 TDV8 VSE
mudknight Member Since: 21 Sep 2012 Location: birmingham Posts: 73 ![]() ![]() |
I can't read anything on the dash as it's too piculated. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Fuel pump maybe? If it's turning over but not firing. There is a secondary pump under a hatch towards the back of the passenger side, if you open the hatch is the pump making any noise? Might be worth an "attitude adjustment" with a hammer if you can't hear anything, (maybe check the fuses first!)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
fuel pump knackered??? |
I've fuses and swooped relay , will check if I can hear pumps next . Sounds big money if it's the pump. |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
It's not too pricey, and there are cheap options but in my experience they don't run at all quietly. Having said that you can get one for £30 if money is tight and then swap out in a couple of months.
I'm usually good at using the hitting stick , will give it a go . Cheers |
