Home > General > What's your mpg?
Page 11 of 12 <123 ... 101112>
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
4.4 TDV8
31.2 - which is excellent for such a huge vehicle, I think (and better than the 26.7 I used to get out of my 3.6 L322) 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #509416 21st Mar 2019 10:21am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
32 mpg - I’ve been really pleased with this. 2016 SDV8 AB
Post #509424 21st Mar 2019 11:33am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
On the 2011 5.0 S/C I just bought I'm currently around 11-12mpg- rather addictive that loud pedal! Laughing
I expect it will improve somewhat when (if) the novelty wears off! Thumbs Up Formerly happymadison1978
Post #509426 21st Mar 2019 11:44am
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
If you do longer runs at motorway speeds, certainly 20+ mpg is achievable. I average about 21 mpg with a mix of cross London and motorway journeys.
If you're mainly stop/start around town, and/or enjoying the loud pedal, even 12mpg is pretty good! When I'm stuck in bad London traffic I struggle to get 10 mpg...
Post #509453 21st Mar 2019 2:49pm
Stephen.125
@PaulBrown. Thanks for that, good to know Thumbs Up My commute is only 10.5 miles with highway with only the last mile at slow traffic. should hopefully get closer to 16 eventually Cool Formerly happymadison1978
Post #509455 21st Mar 2019 2:59pm
paulbrown22
Stephen - I'd hope that should be fairly easily achievable - I find as long as you can keep a consistent speed >30 mph, reasonable mpg is possible even with the 5.0 S/C. It's the stop/start driving and bursts of acceleration that really hammer it.
Once you've stopped enjoying the noise you can try the next challenge of maximising your mpg Smile
Post #509464 21st Mar 2019 3:37pm
Blueboy1
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I have not long got a 2011 4.4 tdv8 changed from a td6 3.0 2004 and must admit I have a heavy right foot and was getting 19mpg in the 4.4 Very Happy but drove it sensible today (boring) and got 31 mpg on a 45mile journey so happy with that Smile mind you I did not get it with mpg worry in mind Exclamation love the big girl, have a LC which is my play toy for a bit of a blast which going quick Wink can get that to under 10 mpg Very Happy Very Happy
Post #509476 21st Mar 2019 5:52pm
Stephen.125
Thanks Paul!
Haha sounds like a plan Thumbs Up
All the best!
Post #509480 21st Mar 2019 6:46pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
L322 4.4 TDV8
5500 miles of mixed driving over last 6 months
Measured using GPS-based fuel tracking app (TripLog, using TripLog Bluetooth beacon)
Average 25mpg
Best single journey managed 35mpg on 150 mile motorway run on cruise @70mph
A few things to note:
- dashboard indicated mpg is optimistic by about 5% (I know I can change this using IID but cba)
- initially I was using Shell V-Power almost exclusively. I then bought 5L of Archoil AR6900-D (https://www.powerenhancer.co.uk/product/archoil-ar6900-d-max-advanced-diesel-fuel-synthesis/) and use that with standard diesel. My MPG has gone up marginally but expect my engine fuel system is now cleaner and more effective as the Archoil contains more powerful additives than the V-Power. Recommended dose is 10ml per 10L of fuel so it works out just under 2p per litre additional cost and thus between 75-90% cheaper than the premium diesel extra cost over standard.
- engine oil and filter was changed at the start of the 5500mil
- running Pirelli Scorpion Verdes and no bolt-ons such as racks or lights affecting drag. Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #658456 4th Mar 2023 4:59pm
JayGee
Mine's doing a steady 30mpg average and this is mostly M-way at just under 70mph. Fuel offset via IID is now at -5% as this is closer to the actual fill to the brim calculations. Had thought that after having the new thermostat fitted and it's now running at the proper operating temperature (closer to 90 deg rather than 70 deg) it would run more efficiently but I'd say it's using a bit more fuel now.... 2012 TDV8 Vogue (L322)
Post #658458 4th Mar 2023 5:05pm
Dolphinboy
2011 TDV8.
Got avge 28mpg over 1600 miles to Alps and back. cruise speed roughly 75mph.
Post #658463 4th Mar 2023 6:00pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I am averaging 31.4 mpg in the Westminster 4.4tdv8. I have seen as high as 37 on a run at around 60 - 65 mph.
Really impressed by how smooth it is.
Post #658585 5th Mar 2023 10:15pm
Gremlin500
Do some folks REALLY just believe the dashboard readout? Surely not? Shocked Shocked Shocked
The above posts are totally meaningless unless properly validated (which some are, to be fair):
For example, my L405 TDV6 regularly displays consumption values WELL above 30mpg, but when I calculate weekly brim-to-brim fuel consumption using the “second click” method, I usually get 24-29mpg, about 5-7mpg less than the displayed value.
Human nature often seems to desire for some reason to exaggerate the economy of our vehicles, and the manufacturers are no exception, -it sells vehicles. I’m more inclined to believe the worst figures posted here for that reason.
I would encourage all here to gather good, honest data in regard to actual milage covered vs actual fuel recorded at the pump, and type of journey be it urban city commute/Sunday A-road cruise/Motorway blast.
Just don’t read it off the dashboard Rolling Eyes
Especially so for diesel vehicles with DPF regen which can eat fuel at an alarming rate under regen. Thud “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #658589 5th Mar 2023 11:45pm
Dolphinboy
take 10% off the computer reading and you will be about right.
Post #658592 6th Mar 2023 12:26am
Martin2
I log my mileage and fill ups and there are big differences in the computers accuracy between manufacturers. My FF is by far the worst at close to 9%, my BMWs were 3-4% out and the closest is my wife’s Golf R, which has a 0.8% variance over 45k miles.
So, it’s not impossible to be fairly accurate, 9% is ridiculous. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #658595 6th Mar 2023 6:44am
