Home > In Car Electronics (L322) > Amplifier Water Ingress / Most Fault - 2011
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Had a few loud noises and crackles from the speakers, had a bit of an invest and found water in the amplifier. Have dried it out and refitted, but touch screen refusing to move off the Range Rover logo at the moment. Connected amplifier to a supply before fitting and had a light at the most connector.
With the engine running I have disconnected each Most connector in the boot and each is lit up apart from the amplifier connector. Does anyone know what is before that on the chain? Not yet tried a battery reset. 2004 TD6 - Gone
2011 4.4 TDV8
Post #506113 23rd Feb 2019 2:13pm
Baltic Blue
Don’t ask me any questions it’s far too complicated for an old git like me Rolling with laughter
Post #506114 23rd Feb 2019 2:55pm
Shaun
Thanks, will have another look tomorrow. May order myself a link connector for the Most Bus to make things a bit easier. 2004 TD6 - Gone
2011 4.4 TDV8
Post #506119 23rd Feb 2019 6:44pm
..or use a bic pen ..
Post #506140 23rd Feb 2019 9:06pm
Shaun
Sacrificed a bic pen to link the amplifier Most out and the system comes to life, a new amplifier then. Sad Also have a 2014 amplifier in a 2011 car, so it's had previous!! 2004 TD6 - Gone
2011 4.4 TDV8
Post #506194 24th Feb 2019 1:53pm
Shaun
Purchased a new old stock amplifier and slave fitted. Everything now comes to life, but no sound. I have one spare connector on the amplifier, I am presuming this is correct. Heard it mentioned a battery reset can sort things out. How long do you disconnect it for and do you need to short battery leads together?
 2004 TD6 - Gone
2011 4.4 TDV8
Post #506815 1st Mar 2019 10:46am
rjff
Have a search for battery reset on here. Cheers
Richard
Gap IIDBT
Post #506870 1st Mar 2019 3:03pm
Baltic Blue
Open the bonnet, then leave it for a while to make sure everything shuts down properly before disconnecting the battery leads.
Then wait a minute or two before holding them together for half a minute or so.
Then reconnect and hold your hands together for a little prayer Rolling with laughter
Post #506871 1st Mar 2019 3:15pm
Rob99
It's also in the wiki.......
http://www.fullfatrr.com/forum/post67804.html#67804
.....and as Mike says....a small prayer Whistle 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #506878 1st Mar 2019 3:49pm
Shaun
Been told that this may need programming to the car, is this correct? 2004 TD6 - Gone
2011 4.4 TDV8
Post #507001 2nd Mar 2019 2:10pm
Baltic Blue
Item number 8 on the installation instructions seem to suggest it will need some sort of programming.
Mike.
Sorry I can’t master posting full PDF. from my iPad ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #507003 2nd Mar 2019 2:36pm
Shaun
Ok then, is this something that can be done with an IID tool? Was considering getting one. 2004 TD6 - Gone
2011 4.4 TDV8
Post #507030 2nd Mar 2019 6:07pm
Shaun
Car finds the new amplifier ok, and I have selected premium which I believe is right. Still no sound, any suggestions? 2004 TD6 - Gone
2011 4.4 TDV8
Post #509616 23rd Mar 2019 11:02am
GGDR
If you have little HD symbols on your speakers then you have the 1200w system. I think 'Premium' means this - the 1200w system. Otherwise try it on another setting on the IID options?
. Cheers, Greg
Post #509619 23rd Mar 2019 11:49am
Shaun
No, it's not HD. Went along with that as it had a premium sticker on the amp. Will try a different one. 2004 TD6 - Gone
2011 4.4 TDV8
Post #509628 23rd Mar 2019 12:34pm
