Home > In Car Electronics (L322) > Amplifier Water Ingress / Most Fault - 2011
mjdronfield
I would like the HD amp in mine, but I’m told the wiring is different.....
I take it you just got the same part number as the amp you already had?
If it helps, I believe the 1200w HD amp numbers are below.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #509635 23rd Mar 2019 2:50pm
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
It is the same part number as the one that came out. 2004 TD6 - Gone
2011 4.4 TDV8
Post #509654 23rd Mar 2019 8:43pm
Shaun
Would anyone be able to tell me what a standard Logic 7 amp, not HD should be configured as. Just to save trial and error. Thanks. 2004 TD6 - Gone
2011 4.4 TDV8
Post #509769 25th Mar 2019 1:16pm
ur20v
A Trap
Made in a France is your problem
Post #510807 3rd Apr 2019 7:19pm
