![]() | Home > In Car Electronics (L322) > Amplifier Water Ingress / Most Fault - 2011 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Don’t ask me any questions it’s far too complicated for an old git like me |
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 ![]() ![]() ![]() |
Thanks, will have another look tomorrow. May order myself a link connector for the Most Bus to make things a bit easier. 2004 TD6 - Gone
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
..or use a bic pen .. |
Sacrificed a bic pen to link the amplifier Most out and the system comes to life, a new amplifier then. |
Purchased a new old stock amplifier and slave fitted. Everything now comes to life, but no sound. I have one spare connector on the amplifier, I am presuming this is correct. Heard it mentioned a battery reset can sort things out. How long do you disconnect it for and do you need to short battery leads together?
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Have a search for battery reset on here. Cheers
Open the bonnet, then leave it for a while to make sure everything shuts down properly before disconnecting the battery leads.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
It's also in the wiki.......
Been told that this may need programming to the car, is this correct? 2004 TD6 - Gone
Item number 8 on the installation instructions seem to suggest it will need some sort of programming.
Ok then, is this something that can be done with an IID tool? Was considering getting one. 2004 TD6 - Gone
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
If you have little HD symbols on your speakers then you have the 1200w system. I think 'Premium' means this - the 1200w system. Otherwise try it on another setting on the IID options?
No, it's not HD. Went along with that as it had a premium sticker on the amp. Will try a different one. 2004 TD6 - Gone
