![]() | Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I’m glad I ventured into the L405 section. It’s been an education. Well done Graeme. I’ve seen another vid of a D4 also with a runaway motor. ______________________________
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Here's one being fitted to my son's D4.
Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39 ![]() ![]() ![]() |
Good news in that the engine has run today. However not running correctly due to blocked DPF and cat system in the exhaust system which is probably due to running on oil? Suspect this is going to go into week 10 now. |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 187 ![]() ![]() ![]() |
Late to this but my Disco2 failed like this. Porous engine block - if you got beyond 70k miles you didn't have it. Drank its own oil, engine ran away, clouds of white smoke. Kaput. Got it fixed then got a D3....then an L322, then the L405. 17 MY Corris Grey 4.4 VAB
Week 11 tomorrow. Cats and DPF filter now replaced but new engine not running very well. Now looks like a faulty injector so waiting for parts again! Suspect it’s going to be 2019 before I get it back now. |
Now in week 14 and had the car back briefly last week. Car vibrates at 1200-1400 revs at constant speed. If change down a gear this vibration stops. Any Ideas? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2595 ![]() ![]() |
Set fire to the dealership? |
Engine mounts? Torque converter? |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hi all
Finally after 17 weeks (tomorrow) got the car back again and the new engine now appears to be working correctly.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Wow Richard, that's over four months.
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
Didn’t the new motor include injectors or was it a bare block? ______________________________
No, injectors not supplied with bare engine which in the end were all either faulty or out of spec when tested. Tips damaged running on engine oil. There are apparently no Land Rober tests to test injectors on the engine.
