![]() | Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died |
Highly unlikely. When my turbo 'went' I was accelerating off a roundabout onto a dual carriageway - so I was heavy on the accelerator. There was a metallic ping and then bye bye engine!! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39 ![]() ![]() ![]() |
Just had a quote of £26,835 including Vat
![]() I went out and bought a replacement Range Rover (but mine was an L322 TDV8) Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue Last edited by DMRR on 16th Oct 2018 6:30pm. Edited 1 time in total |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
£26k jeez I bet youre not happy, blimey thats horrific. Have you tried a good independent such as Green Oval, see what they can do, used engine, replace etc. Im gutted for you, thats terrible. BMW i3 Electric Car
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
A premature assumption unless it is determined that this particular engine had a single drain. |
From what I understand about the drain problem, it wouldn't do it anyway. It really needs a catastrophic failure of the turbo seals to put a substantial amount of lubrication oil into the intake. Generally they empty the sump in around 20 to 30 seconds or thereabouts. The drain mod doesn't have anything like this amount of oil in play prior to the mod. BMW i3 Electric Car
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Found that post I was referring to: http://www.fullfatrr.com/forum/topic47304.html .[/quote] Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
I have decided to build an automatic kill facility for mine to close the throttle butterfly, as I did for my TD5 D2. I had hoped that the ecm would close the butterfly in times of uncontrolled revving, albeit with the ignition still switched on, but obviously the butterfly is not being closed other than to increase airflow through the EGR valve as required.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 909 ![]() ![]() ![]() |
Good news for those without the mod in terms of not worrying about any possible catastrophic engine failure related, although if there was a link and given the runaway sympton, guessing it becomes a critical safety issue infoming a manufacturer recall and replacement at LR's cost? |
Its only my view and I could be completely wrong, I'm not a betting man but Id put my wages on this one. BMW i3 Electric Car
Sure you're right, given how many unmodified turbo drain 4.4 tdv8's out there but catastrophic engine failure / runaway engines seemingly very rare. |
I completely agree, in my view IF diesel runaway could result from the turbo drain problem, Land Rover would have to do a safety recall, the potential danger would be immense. BMW i3 Electric Car
LR replaced many 3.0 TDV6 secondary turbos when early D4s smoked because they considered that the turbos were faulty before changing their view that the problem was resolved by changing the drain to go directly to the sump. My D4 had 1 replaced then later was in line for its 2nd well after end of warranty but I fitted the revised drain myself instead. If the drain is not totally free then the oil will exit via the the seals, which really aren't seals, just a normally harder way for the oil to escape. |
Engine has now been examined to confirm metal particles in the oil and larger fragments in the oil filter. New engine required.
