Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died
Page 7 of 7 <1234567
Richardince
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Things are progressing better now and possibility that the engine will be fired up tomorrow. Hopefully it will be back before we hit the 9 week point on Saturday.
Post #498252 11th Dec 2018 9:35pm
rar110
I’m glad I ventured into the L405 section. It’s been an education. Well done Graeme. I’ve seen another vid of a D4 also with a runaway motor. ______________________________
Post #498287 12th Dec 2018 11:25am
GraemeS
gonna_go_double_r wrote:
Nice one Graeme, any pics?
Here's one being fitted to my son's D4.
Post #498349 12th Dec 2018 7:20pm
Richardince
Good news in that the engine has run today. However not running correctly due to blocked DPF and cat system in the exhaust system which is probably due to running on oil? Suspect this is going to go into week 10 now.
Post #498352 12th Dec 2018 7:40pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Late to this but my Disco2 failed like this. Porous engine block - if you got beyond 70k miles you didn't have it. Drank its own oil, engine ran away, clouds of white smoke. Kaput. Got it fixed then got a D3....then an L322, then the L405. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #498370 12th Dec 2018 9:16pm
Richardince
Week 11 tomorrow. Cats and DPF filter now replaced but new engine not running very well. Now looks like a faulty injector so waiting for parts again! Suspect it’s going to be 2019 before I get it back now.
Post #499373 21st Dec 2018 7:17pm
Richardince
Now in week 14 and had the car back briefly last week. Car vibrates at 1200-1400 revs at constant speed. If change down a gear this vibration stops. Any Ideas?
Post #501781 16th Jan 2019 10:51am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Set fire to the dealership?
Post #501782 16th Jan 2019 11:31am
GraemeS
Engine mounts? Torque converter?
Post #501784 16th Jan 2019 11:41am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
Something similar happened to a chap over on the RRS site recently
http://www.rrsport.co.uk/forum/post573367.html#573367
Jim
Post #502017 18th Jan 2019 4:48pm
Richardince
Finally after 17 weeks (tomorrow) got the car back again and the new engine now appears to be working correctly.
All injectors have now been replaced after testing found them all to be faulty/out of spec.
Another large invoice!
Lets hope this is the end of the saga, nice to have it back.
Post #504524 8th Feb 2019 8:36pm
GGDR
Wow Richard, that's over four months.
Hope they gave you a courtesy car.
Glad it's finally sorted.
. Thumbs Up Cheers, Greg
Post #504526 8th Feb 2019 8:40pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
Thumbs Up good to here Richard. I did wonder how things were going but 17 weeks is a bit of a wait. 2009 Vogue SE Zermatt silver
Post #504528 8th Feb 2019 9:07pm
rar110
Didn’t the new motor include injectors or was it a bare block? ______________________________
Post #504544 9th Feb 2019 3:57am
Richardince
No, injectors not supplied with bare engine which in the end were all either faulty or out of spec when tested. Tips damaged running on engine oil. There are apparently no Land Rober tests to test injectors on the engine.
Bare engine , new turbos , intercoolers , DPF. Cats plus lots of other parts fitted.
Post #504629 9th Feb 2019 4:43pm
