![]() | Home > In Car Electronics (L405) > MY17 - My18 infotainment upgrade |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
I tried everything the Tech asked me to try but no improvement. Left a message for the service advisor yesterday but no response. Sent an email but no response. Sent another email to point out that I now have issues with Spotify not loading.
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Mine was in today, they are saying they have tried three times to upgrade from 18C to 18d to solve the apply car play remote start issue, but each time its failed, they are now trying over night before escalating to LR.. You would think they would have solved a simple upgrade issue... |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
If the software has been updated from a version earlier than 17C (highly likely in this case) then the following notes from Topix apply:
Looks like the 'tech' only did half a job and didn't read the instructions properly. |
I'm pretty sure the tech said he'd installed the voice database and it was his suggestion that I update the map to see if it made a difference. He said that the update had to be carried out to ensure the voice database worked.
Seems I've been emailing a guy who's off sick!!!
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 ![]() ![]() ![]() |
Huwrhys I have the same issue with my upgrade in that I cannot connect my iPhone via Bluetooth (works fine plugged in via CarPlay). Well to be exact it appears to be able to play music via Bluetooth but the phone functionality will not connect. Voice commands I've not really played with but the Voice Command button works to activate Siri when CarPlay is running as expected. |
What’s needed with LR Dealerships is patience. They will eventually get it sorted but it just takes time. I can’t fix it so I just have to wait for them to get it sorted. |
So my car is still in the dealer!! It will not load 18D but apparently LR have been dialled in and there are two later versions they are also trying to apply Local dealer called me today and said they just have to keep trying to apply the software, eventually it will work!!! At least they have provided a loan car... |
Mine goes back in on Thursday for them to get the software sorted. I'm hoping they don't take too long as I'm off to Devon the following week to do my LR experience at Honiton. I've managed to get the Carplay working and it seemed to be the phone which had an issue. I cleaned the lightening cable socket by switching the phone off and using some alcohol and a cocktail stick. Now it's working well. The Bluetooth remains unusable as does voice control but Siri works for the messaging side of things. We'll see how it goes. |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Even the very latest ICTP software is buggy as hell. Collected my car yesterday and on the way home noticed the ambient lighting in the car wasn't on. Tried to switch on via the touch screen and not all the zones would switch on! Then Bluetooth wouldn't pair the phone! |
My car is back in the dealers to have the bluetooth connectivity restored and the voice activation also. A further problem with the Apple Carplay is that if I use Waze and then go back to Spotify the program won't load. If I'm listening to music and take a call the music won't restart whatever I do.
Mine is back they could not update to 18D even though they had it for 5 days.. Apparently LR have phase 5 out soon which should fix the cars that will also not take the 18D update, so i am having to wait for that... |
Mines done and it all works! I was treated like Royalty and they couldn't have been nicer. Cups of coffee and smiling faces. I was asked if I wouldn't mind showing the tech guy what was wrong so as to ensure he understood what the issues were and I met with Matt who'd been the guy I spoke to on the phone when we tried to sort it from my end. Very knowledgeable guy he is too. I couldn't fault their care at all. They said they found 7 configuration faults which should have been checked when it was installed last week. They reinstalled the voice pack and it sorted everything including the bluetooth issue.
Mine had the 18D update and was supposed to have the Smartphone Integration Package activated. When it was returned there was no sign of Apple Car Play and to add insult to injury now none of the audible prompts work.
