Home > Maintenance & Mods (L322) > Battery charger
Balloonengineer
Battery charger
Here is a topical one as it is snowing outside
What battery charger have you got, and how do you rate it?
I have an electronic one and an old fashioned Bradex (30+ years old) with an ammeter, and I prefer the old one as at least I can see what the battery is doing
But I'm interested if there are any outstanding chargers out there...….
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #502622 24th Jan 2019 11:43am
CTek .
Post #502624 24th Jan 2019 12:00pm
as above ..the ctek [7?] seems to be the most bought on the forum..
Post #502625 24th Jan 2019 12:04pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Permanently installed DEFA 5A charger. Gives you a small socket in the front to connect the mains.
https://www.defa.com/product-category/char...s/onboard/ 2007 L322 3.6 TDV8 Stornoway
Post #502628 24th Jan 2019 12:26pm
CtekMSX7, ideal had one for years Thumbs Up
Post #502635 24th Jan 2019 1:15pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
CTEK MXS 10...……10/10 Thumbs Up
Post #502636 24th Jan 2019 1:21pm
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
CTEK MXS 5.0, Does the job The worst thing about being retired is you miss out on all the bank holidays
Post #502722 24th Jan 2019 11:59pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
CTEK MXS10 - tried all the rest including the MXS5 and the 10 is more than capable of doing the job on the TD6 Smile
Post #502729 25th Jan 2019 1:58am
Lester Burnham
My Ctek 5.0 works eventually but seems to struggle with the AGM battery. A full charge takes a long time whereas it can recover most other normal batteries overnight no matter how goosed they are.
Post #502734 25th Jan 2019 7:27am
supershuttle
CTek also bought the Aldi one as a backup (not used) Geoff
Post #502743 25th Jan 2019 8:42am
rjff
Aldi.
Keeping it topped up OK, takes quite a while if battery is at low charge. Cheers
Richard
Gap IIDBT
Post #502751 25th Jan 2019 10:48am
Baltic Blue
Whenever I go on holiday I leave my CTEK 5 connected via the towing socket. It takes seconds.
Post #502756 25th Jan 2019 11:51am
Paul thornton
That looks like a nice bit of kit Mike!
I use the Lidl one. It's not quick if you have a flat battery but great for keeping it topped up.
I left mine on for a couple of days before attempting to start the car after returning from a 2 week holiday.
Post #502761 25th Jan 2019 2:33pm
S.Hafsmo
The DEFA socket is a bit sleeker.
Post #502771 25th Jan 2019 5:06pm
Baltic Blue
Has anyone monitored the battery voltage on a 4.4 tdV8 AGM battery whilst it is on long term trickle charge? I connected my CTEK 5 on Friday lunch time and noted it was 12.4v before switching on the charger and then 12.8v after a few minutes.
It was up to 13.2v by Saturday morning, but because I was not using the car Saturday I just left it.
It is now showing 13.8v (Sunday lunch time) so 48hours later.
The battery is 6 months old, but I am a bit surprised it took so long to get to what I presume is now fully charged. ?
Post #502969 27th Jan 2019 4:42pm
