Home > General > What Did You Do In Your Full Fat Today
Page 290 of 377 <123 ... 289290291 ... 375376377>
Redbaron
Gave the old girl a wash (including the roof) which was largely pointless but made me feel better.
The. Operation maintenance was initiated:
- new front disks/pads/clips/pins and wear sensor. (No more squeaky brakes!!).
- engine oil and filter.
- air filter (half a cornfield in the air box- had to hoover it out).
- MAF clean (started and stopped a few mornings ago).
- supercharger oil (easy but still a t**t with big hands - oil was grim).
- thermostat (I swore, a lot - now warms up quick and stays at operating temp).
- wipers (I can seeeeee).
- GPS receiver - didn’t have time. Job for the summer.
Post #502511 23rd Jan 2019 9:50am
Rob99
Have to say RB, that's an impressive workshop..........and a gantry crane, nice Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #502530 23rd Jan 2019 2:31pm
Gsxr1250dave
Swopped out the aux heating motor, cabin warms up nice and quick and I can control the heat drivers side no matter what the engine revs are
Post #502553 23rd Jan 2019 5:17pm
Ballogie
United Kingdom 2004 Range Rover HSE 4.4 V8 Giverny Green
Have you a link to that item? I'd love one
b348xyx wrote:
Got my key cover Smile makes it look alot nicer then before. £1.33 from china.
Post #502794 25th Jan 2019 8:47pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Here you go Ballogie:
https://www.aliexpress.com/item/New-3-Butt...4c4dnfAeNl
Post #502813 25th Jan 2019 11:43pm
Ballogie
Post #502888 26th Jan 2019 8:39pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Just had a full service
Just need to get the viscous fan off to change the belts just couldn’t shift it today. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #502976 27th Jan 2019 6:54pm
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Added some subtle bling...
Completely justified I feel, to finally get rid of the very annoying rattle of decayed baffles in the drivers side exhaust. It also makes something of the fairly boring straight pipes fitted as standard Thumbs Up
 Life is what happens while you�re making other plans.
Post #503033 28th Jan 2019 11:48am
Ballogie
140 mile motorway trip Edinburgh to Aberdeen. Cruise set to 70mph. 22.7mpg. 4.4 V8 2004
Post #503261 29th Jan 2019 8:15pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Pretty good MPG there Smile better then I get. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #503268 29th Jan 2019 8:57pm
Ballogie
Cold Start. Aberdeenshire
[/img]
Post #503495 31st Jan 2019 6:49pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
MOT today, passed (always a relief) but advisories on front and rear brake pipes (had the fore/aft longitudinals on the near side replaced a few years ago). Also nearside rear lower bush noted as being worn although play not excessive. I'll get these sorted when weather a bit kinder and bank balance recovered a bit Confused
Whilst a service was getting done, the thread on the sump drain got stripped so had to have a helicoil repair done.
I'll look to get one of those locking drain plugs fitted next time oil due a change.
Only done 8000 miles in the last couple of years Shocked Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #504043 5th Feb 2019 4:05pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Finally, removed the injectors from my TD6 and sent them off to be refurbished.
Three came out quite easily, two not so much, and the last *7%$!!
Removed because I had a misfire, which was obvious when I removed the engine covers and injector No5 was covered in a black tar substance!
Post #506891 1st Mar 2019 4:45pm
nearlee
Wales
Not me, but came out this morning to find someone has crashed into the drivers door, Big Cry Big Cry Big Cry Remember:- amateurs built the ark
Proffesionals built the titanic
Post #507041 2nd Mar 2019 7:14pm
Baltic Blue
A quick trip over into White Rose country to meet Bradders and collect his old starter motor, thanks very much and a pleasure meeting you.
As an added bonus my DPF soot level got a good burn... 19.9 when I set off, 2.7g back home Thumbs Up
I really should take it on more long runs 😁😁.
Post #507312 4th Mar 2019 2:22pm
