![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Hopefully these links will work Greg |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
Just proves what a good job you did Greg. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 ![]() ![]() ![]() |
Is there a condensed version of this with a step by step guide of how to diagnose with an IID? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
IID diagnoses this for you -- I have a persistent fault code as the title of the thread -- will not clear -- if your IID isn't showing the code then it's unlikely you don't have the problem Current: 2011 FFRR Vogue SE 4.4 TDV8
Cool. From reading the whole thread, it seems the best route is to pay an MD / Rovertune to do it...? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
No sorry haven't done my write up yet
As Bushy said it'll come up as the error: P040D-00(2F) EGR temp sensor A . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
I don't know about changing something that aint broke,
Thanks and agreed |
I will be doing a write up when I get a chance.
I defo have the code (new IID working |
Rob,
Well I passed the new, stricter MOT smoke test around a week ago. I was worried. I was also worried they would see my DPF that has been cut out, cleaned and refitted around a year ago. But that was no bother, they said fine.
Based on learnings above and throughout this thread,
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2662 ![]() ![]() |
What a thread, just activated my IID, loads of faults cleared, but I have this error code, don’t suppose anyone has had this done by pentland ? |
