![]() | Home > Maintenance & Mods (L322) > Handbrake Module - Save me from the £1,800 that they want |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Pls fill in your vehicle details...
WCA Member Since: 15 Jan 2017 Location: Hampshire Posts: 26 ![]() |
2007 L322 RR 3.6TDV8 Vogue. EHB actuated by switch not lever. |
Just added that to my profile too so hopefully will show on this post L322 RR 3.6 TDV8 |
How do you know there is no over heating? (this will be in the handbrake module which is tucked away in the rear subframe)
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
You could try these: http://www.bba-reman.com/gb/index.aspx |
Okay - I am going to have a quick look around and see what stuff looks like. Disconnect electrical connections, clean and refit, try and lube the cables to the wheels etc. Nothing major because I can find nothing on Google ab out this issue other than 'replace the unit'.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I had an EPB replaced on my 2007 VSE, lots of suspension parts had to be dropped including the rear subframe. 2015 4.4 AB
Hi Dolph - that is what the garage told me, hence the £1800 cost.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
Would something as simple as reading fault codes be a start? Perhaps clearing them and seeing if that solves the warnings? |
The garage tried that but no joy L322 RR 3.6 TDV8 |
Well I have had a poke around and cannot see anything obvious. I have also just dropped my phone while using it as a torch . Not only did the screen crack, it landed on my face first and has given me a split lip!
I bought a secindhand one from a specialist RR breaker in Latvia and had it checked out before fitting so it was a quick swap over to save down time. 2015 4.4 AB
Keith Gott in Alton ? (MD)
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Joe are the epb the same as the disco ? |
