Home > Maintenance & Mods (L322) > Handbrake Module - Save me from the £1,800 that they want
WCA
MOT Failure because the handbrake works perfectly but it gives an over heating warning message.
There is no over heating and no issue but with the warning there is also no MOT
Suggestions, remedies etc?
The recommended action is a new handbrake module for £755 which fitted comes to £1,800.
PLEASE- Suggestions, remedies etc?
Post #500573 4th Jan 2019 10:58pm
GGDR
Pls fill in your vehicle details...
. Cheers, Greg
Post #500574 4th Jan 2019 11:04pm
WCA
2007 L322 RR 3.6TDV8 Vogue. EHB actuated by switch not lever.
Post #500595 5th Jan 2019 9:41am
WCA
Just added that to my profile too so hopefully will show on this post L322 RR 3.6 TDV8
Post #500596 5th Jan 2019 9:43am
How do you know there is no over heating? (this will be in the handbrake module which is tucked away in the rear subframe)
Not heard of this issue before, but it does seem the only thing to do is to get the handbrake module out (a right PITA by the looks of things) get it overhauled, and try it again
Do you have a copy of the manual for 2007 model (see wiki) then you can assess the work required. .
Post #500597 5th Jan 2019 9:50am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
You could try these: http://www.bba-reman.com/gb/index.aspx Thumbs Up
Post #500598 5th Jan 2019 9:59am
WCA
Okay - I am going to have a quick look around and see what stuff looks like. Disconnect electrical connections, clean and refit, try and lube the cables to the wheels etc. Nothing major because I can find nothing on Google ab out this issue other than 'replace the unit'.
I am down in Southampton, so close to Winchester. Joe - you may get a plea for help if this all goes wrong!!
Cheers
WCA
Smile L322 RR 3.6 TDV8
Post #500609 5th Jan 2019 12:10pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I had an EPB replaced on my 2007 VSE, lots of suspension parts had to be dropped including the rear subframe. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #500611 5th Jan 2019 12:21pm
WCA
Hi Dolph - that is what the garage told me, hence the £1800 cost.
Can't see a frickin thing under the truck at the moment L322 RR 3.6 TDV8
Post #500615 5th Jan 2019 12:33pm
chugga90
Would something as simple as reading fault codes be a start? Perhaps clearing them and seeing if that solves the warnings?
Post #500618 5th Jan 2019 12:42pm
WCA
The garage tried that but no joy L322 RR 3.6 TDV8
Post #500619 5th Jan 2019 12:43pm
WCA
Well I have had a poke around and cannot see anything obvious. I have also just dropped my phone while using it as a torch . Not only did the screen crack, it landed on my face first and has given me a split lip!
So having discovered I can't fix it by swearing and breaking a 2 month old Galaxy S9 phone, bloodied and cold I am going to call it a day.
Please recommend a RR specialist near Southampton. I will default to Brooklyn 4x4 as they are closest but I wouldn't mind talking to some others to see what they say.
Names and numbers please.
Sad L322 RR 3.6 TDV8
Post #500624 5th Jan 2019 12:52pm
dolph34
I bought a secindhand one from a specialist RR breaker in Latvia and had it checked out before fitting so it was a quick swap over to save down time. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #500630 5th Jan 2019 1:11pm
Keith Gott in Alton ? (MD)
or Joe90's house Wink .
Post #500641 5th Jan 2019 2:06pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Joe are the epb the same as the disco ? Thumbs Up
Post #500677 5th Jan 2019 6:52pm
