Home > Maintenance & Mods (L322) > Handbrake Module - Save me from the £1,800 that they want
WCA
Joe - if your garage has the toys and tools to drop the rear sub-frame etc and you know what you are doing then I am happy to pass tools, tea and donuts all next Saturday. email me L322 RR 3.6 TDV8
Post #500681 5th Jan 2019 8:24pm
You might want to remove your email address from the post above Shocked .
Post #500698 5th Jan 2019 10:09pm
We still really do not know the extent of the problem.
The PBM is overheating ? What evidence is there of this? What does the car report on the dash ?
My IIDTool will only control the position of the PBM no diagnostics, but will probably clear any faults (could be an historic issue that has now resolved?) At worst we will see if/how/when the fault returns. (Your garage may not have diagnostics specific enough ?)
What is your plan ? To replace the PBM module ? / get it checked over ? / refurbished ? Does it need coding to the car ?
As previously said, it is quite a job:
1. Get it in the air
2. Release dampers and suspension and depressurize both sides - not sure why
3. remove exhaust
4. lower rear subframe (but only by 40mm in total !) (this is best done by getting some longer bolts rather than using jacks)
5. undo all manner of cables
6. Remove PBM module
At best this would be a day to get it out and a day to get it back in, assuming everything comes undone and can be reused.
Would have to do it on my drive, unless I get a decent outdoor cover for my treasured MG ! .
Post #500703 5th Jan 2019 10:28pm
Some bedtime reading (not all necessarily related but you never know with a FFRR)
https://www.pistonheads.com/gassing/topic....;t=1197293
https://www.disco3.co.uk/forum/epb-repair-...91299.html
https://www.rangerovers.net/forum/43-range...fault.html
Other checks possibly required:
Speed Sensors
Condition of rear brake shoes and drums, and adjustment/settings
Steering Angle Sensor (daisy chain effect)
An unjam of the PBM (if jammed might be why it is overheating ?) .
Post #500708 5th Jan 2019 11:09pm
