![]() | Home > Maintenance & Mods (L405) > L405 SDV8 oil leak help needed |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
The 4.4 in at least the earlier L405 suffers the same oil leaks from the gaskets above and below the oil filter housing and the O-rings at the back of the oil filter housing as the 4.4 in the L322. I believe that the filter housing gets too hot due to being bolted to the top of the EGR cooler and as yet LR haven't revised the gaskets using a material that withstands the heat. O-rings are easy to upgrade by fitting Viton versions.
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Thank you very much for the reply. Do you by any chance have any more information on the subject? Any guides or images would be greatly appreciated
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Plenty on here Charles, search Oil Leak 4.4 TDV8 or Oil Cooler 4.4 TDV8 or o-rings oil leak 4.4 TDV8.
Thank you for the reply. So I assume the assembly must all be the same then.. as far as I could see it looked visually different, in that the turbos are situated at the rear of the engine etc. It also looks more difficult due to the engine being set furthur back to the L322 and it appears to cover the rear access to remove the intake manifold. I will have a look atbthe threads, Thank you again |
At first glance on the 322, there is limited access but simple (two nuts) removal of the large cabin air intake box opens up the access space. No idea if the 405 has a similar set up.
Thanks again for the support with this. Yes I have warrenty, my issue is moreover the timing, I'm sometimes stationed overseas, and I have a few imminent trips coming up. My local Landrover dealer say they can't fit me in to even look at it until the second week of December |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Do these pictures help you any ?
Mike,
Green arrow shows “O” ring turbo oil feed pipe connection.
That explains having to remove the manifold to gain access then... I wander what my chances are of it being just an O ring on that pipe rather than the entire oil cooler.. |
Charles you should check for oil in your coolant tank.
I have checked the tank and It's clean and no oil contamination thankfully. However I did use 2L of oil yesterday to do only 18 miles, and when I parked up smoke was bellowing out from the bonnet, I poped the bonnet quickly and found it was like someone was trying to smoke signal the neibouring town! I was more worried about it causing a fire.
err yeah that 's a lot of oil coming out....
I would go back to square 1.
