![]() | Home > Maintenance & Mods (L405) > L405 SDV8 oil leak help needed |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Thanks again for the reply, this was also my first thought and I took it back to the dealer who serviced, they checked and the O ring was damaged so a new one was fitted. But the issue still persists, so I think it may have been just bad luck.. or maybe new clean oil dislodged some carbon etc.. I'm grasping at straws I realise here! |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Looks like Baltic and I are giving the same advice again (we've both been there and got the "i've replaced my oil cooler seals" tee shirts) |
I did think that it could be residual oil, but I checked the dipstick level and it was saying add 1.5L oil so it's defiantly still loosing oil... |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
while I hate to be cynical, it never ceases to amaze me the number of stories I hear of cars being perfectly fine going in for routine services and miraculously within a day or two of that service, faults suddenly appear that require fixing.
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
There’s usually a connection....in that you had the vehicle serviced and then soon afterwards it starts throwing oil out. Then the garage says the O ring was incorrectly fitted anyway.
I'm going to kick up a fuss this morning. Will update you all later |
A litre and a half is a lot of oil to have lost and it would not just be showing at the bell housing, but would have Greenpeace on your tail thinking that another Torrey Canyon had appeared. The only way to be sure is for the garage to clean it all up with Gunk or some other engine degreaser and wait for new signs to appear. That would also help identify the location of the leak. Mike |
One last final sanity check.... I have topped it up to the correct level, now I will endure the smoke in case it really is just burning off residual oil, I have an off road section of land I think I may park as vertical as possible in case all the oil that did leak from the oil filter housing has collected and pooled inside the lover V of the engine.. may be I will also drench it in brake cleaner and hopefully dissolve any remaining oil |
swissomatic Member Since: 16 Feb 2016 Location: Charleston SC Posts: 49 ![]() ![]() ![]() |
Just a quick suggestion. Be very careful of pouring brake cleaner in there. Firstly it could be a flammable source and catch on fire depending on brand and consist, oil tends to have a higher flash point. Let it dry out properly. Secondly do not let it touch any of the sealed bearings on alternator, air conditioner etc as it has a bad habit of flushing out permanent bearing lubricant if it manages to penetrate the "sealed" joint. i have seen a number of examples of failed bearings as a result of aggressive degreasing, brake cleanser cleaning of greasy parts (especially clutch throw bearings) which only fail after you have put everything back together and driven about half a mile.
Thank you swissomatic for your reply.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
The garage will have used an oil extraction pump to remove the old oil, and if you go back they will be able to suck out most of the leaked new oil using the same pump. G reg 2.5VM Vogue Portofino red 1991- 1999
Baltic blue, they Did not use an extraction pump, they dropped the sump and drained from beneath (I watched them and stood at their side as they did it) But great idea on the extraction pump, maybe I can catch any excess that is sitting in the V with a pump. |
Unbelievable |
I am interested to know how?
