Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG
Page 5 of 6 <123456>
GGDR
Mike just adding this from Salter121, he bought a dead 2011 TDV8 and reported:
Quote:
After 115k, following a turbo fail, this L322 Range Rover 4.4 TDV8 threw in the towel; absolutely destroyed the engine. From what I am told by the dealer, the garage they originally took the car to failed them; originally advising to replace the turbos without performing some basic checks for internal damage to the engine. After replacing both turbo's ( Shocked ) and still not being able to get the engine to start they eventually started stripping it down to investigate further.
His full story of re-engining a 4.4TDV8 is here: http://www.fullfatrr.com/forum/topic47799.html
Turbos failing on the 4.4 are rare but I guess possible.
This possible turbo failure on an L405 4.4TDV8 is also one to watch: http://www.fullfatrr.com/forum/post492232.html#492232
. Cheers, Greg
Post #492235 14th Oct 2018 1:50pm
Zeppfish
Mike
2012 Westminster
82k miles
Front lower suspension suspension bushes knackered! (The big ones on the rear section of the lower front wishbone)
Being replaced with poly bushes as we speak 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #493425 24th Oct 2018 6:28am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Using poly bushes on such a nice car just makes me sad. Nothing ruins a comfortable ride like poly-bushes.
In addition they squeak, do not last any longer than rubber if used in high load Places (caster rod bushes etc.), and they can cause additional stress on the rest of the suspension. I've seen suspension control arms break in half due to use of poly-bushes. 2007 L322 3.6 TDV8 Stornoway
Post #493429 24th Oct 2018 7:49am
mark35gun
United Kingdom 2011 Range Rover Autobiography Black TDV8 Santorini Black
2011 4.4 tdv8 ab
new belt tensioner
lower tailgate strut
@ 86,500 miles 2011 4.4 tdv8 autobiography black
2006 td6 vogue buckingham blue
2000 p38 Holland&Holland gone, best car i ever had
1998 p38 vogue oslo blue gone
1998 50th edition v8 defender gone
1997 200 tdi defender red gone
1995 4.6 defender 90 green gone
Post #493726 27th Oct 2018 1:29am
TomCobbly
2011 4.4TDV8 40,000 miles - New starter motor. Fiddly but did it myself
I'm going to refurbish the old one and keep it as a spare. It actually works but often doesn't have enough grunt to turn the engine over. Didn't fancy struggling through another winter with it. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #494670 5th Nov 2018 9:25am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Replace EGR cooler @ 113000kms.50% goodwill from JLR towards cost!! Very Happy Very Happy
 2012 TDV8 Vogue SE 4.4
Post #494697 5th Nov 2018 1:47pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Second starter replaced after another two years... so its about 26 months of life you can get out of those.
First one replaced under warranty, now waiting for a big bill as its not covered again obviously.
Need to get a spare one and refurb myself.
4.4TDV8 2012
Regards
Hoppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #496436 23rd Nov 2018 8:08pm
TomCobbly
The Denso starter motor doesn't lend itself to having the solenoid taken apart to get at the blackened contacts. You have to carefully snip out a welded contact on the outside of the solenoid housing and slide the top off without damaging the connections inside. I looked around for spares and found them for every Denso motor except this one. Just cleaned up the existing ones and put it back together.
I think starting the engine with a reduced battery voltage damages the contacts in the solenoid. Using the FBH could contribute to a lower voltage 2011 4.4 TDV8 Vogue SE
Post #496451 23rd Nov 2018 9:31pm
CS
When my starter motor was replaced (2012 WM) there was a credit/recharge on the bill. I asked what that was about and was told that LR get the starter motors back and refurbish them. The value of the defective motor is credited against the cost of the replacement. So depending on where the work is done there may be less value in keeping the old motor and trying to refurbish it yourself. Only Range Rovers since 1988
Post #496481 24th Nov 2018 1:07pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Is anyone keeping records still?
2012 4.4 TDV8 79000 miles.
Just changed oil cooler/heat exchanger. No cracks, just lower gasket weeping and then dribbling onto bell housing.
New unit fitted as not uncommon to fail around this mileage.
Auto box oil flush and all transmission lubes changed pre-emptive maintenance.
Small wear on rear hub upper bushes. To be changed at next service.
Firm believer in sorting potential problems before they bite you. Forty years of progress. 1972-2012
Post #498859 16th Dec 2018 10:25pm
Baltic Blue
Arbuckle,
I have stopped logging any faults that are just repeats of all the previously known problems.
The thread is probably more use now as a “what to check” guide to people looking to buy a 4.4tdv8.
Post #498904 17th Dec 2018 1:56pm
Frans@Yamorna
BB,was there not talk to publish a list of the range for live values for the values that can be selected?I for one would like to see the live value for engine temp-crusing and then when towing.Charging rate is another one that interest me.
Seasons Greetings to all Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #498940 17th Dec 2018 5:57pm
Baltic Blue
Frans@Yamorna,
I can confirm to you that I am still compiling data for a new post which will be entitled “4.4tdv8 live values”
I have currently got stored on my iPad over 100 screenshots of the iid app showing different live values that I have taken under different conditions, but not including any whilst towing.
It is not easy to get the data, partly because my wife is not always present to hold the iPad and get the screenshots I want, and on several journeys I have accidentally kicked out the iid from the port before getting the pictures.
I am however hoping to publish the first data soon , in the hope that other owners will add to it with their data.
Mike.. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #498943 17th Dec 2018 6:29pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Arbuckle
The wear you have on the rear bushes can you hear a knock over bumps as I am looking to replace mine thought it could be the lower ones
Have there been any visional signs?
Post #498945 17th Dec 2018 6:46pm
Frans@Yamorna
Thanks BB!!Great.
Ha-ha,yes it is easy to dislocate the dongle!!
Looking forward to your new post.Comparing live values will be of great help to solve a problem. 2012 TDV8 Vogue SE 4.4
Post #498950 17th Dec 2018 7:13pm
