Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG
Page 4 of 6 <123456>
Baltic Blue
Thanks, and good luck sorting the restricted performance problem.
Post a picture of the 4 short hoses and I will tell you if they are the original design which split or the modified later type which solve the problem.
PS
I have been offered a very impressive database for fault logging if anyone wants to take it on.
It would be easily adapted for L405 faults if anyone wants to manage a similar L405 Fault History Log.
Post #469300 19th Feb 2018 10:56am
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I’ve had my RR for almost 4 months and within the last month had to replace the oil cooler gaskets, adaptive dynamics wire break & auxiliary belt tensioner collapse all at 74K miles. I do hope I have a quiet period now! Chris
Post #469301 19th Feb 2018 11:06am
GGDR
Hi Mike,
I've had error P040D-00 (2F) Exhaust Gas Recirculation Temperature Sensor A - circuit high.
A quick search here and this came up from mikeyyn:
Quote:
Hi, I had a fault with EGR sensor, fault code P0486-17 (27) Exhaust gas recirculation sensor B circuit - General electrical failure - circuit voltage above threshold
Turned out to be a faulty throttle body. A lot quicker to replace than the EGR and sensor.
Grateful for any tips or further info on this.
Greg Cheers, Greg
Post #470752 2nd Mar 2018 9:51pm
Baltic Blue
Greg,
I have had exactly the same Fault code since early December but have not yet got to the bottom of it,
However I cannot notice any ill effect from it and don’t think it is causing any problems.
Post #470763 2nd Mar 2018 10:13pm
nino_nino
I have the same error massage Greg, apparently it is's not something to be worried about. people have replaced the sensor but the fault comes back.
Nino,
Post #470765 2nd Mar 2018 10:16pm
Fatfred
Try spraying a good egr cleaner down the air intake for starters, just a thought FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #470766 2nd Mar 2018 10:16pm
OtleyDominic
I have just had the EGR sensor replaced and seemed to clear the code and issue?
Post #470769 2nd Mar 2018 10:23pm
GGDR
I've read a bunch of posts on this over the last hour and it seems some people have the fault, leave it and it's fine.
Others not so lucky.
Would be good to know if there are other indicators that might give away whether the engine is being over-fuelled.
It could also be gunked up and there was a suggestion of an intake cleaner.
Has anyone done this? If so how was it, what did you use etc?
. Cheers, Greg
Post #470786 3rd Mar 2018 1:05am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Baltic, only just spotted this thread, I'll update with info soonest, but won't be till after the bank holiday, and only then when I get my IID tool and can find out if I have any as yet unknown gremlins.
Smile
PS how do we get to see the complete log? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #486832 22nd Aug 2018 11:26am
DrRob
Be good to have a stand alone topic in Technical that lists the common issues, how to check if they’ve been done and then a link to a thread/wiki on how they can be fixed... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487304 27th Aug 2018 5:38pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I have had to repair the top near side strut wiring for adaptive dynamics a few months back, and also the PCV for the aircon pump.
Mike, did you ever make the leads up with the silicon wire ? Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #487316 27th Aug 2018 7:36pm
Baltic Blue
John,
Ashamed to say, but I never finished them.
I have got them in my workshop almost ready to fit, but I hit a snag.
The wires at the plug end are very fine and the only way I could see to reuse the existing plug was to cut it very near the plug and join to the new wire, so I decided to do the repair next time one fails.
This is a picture of the official repair loom with a new plug already fitted.
Post #487321 27th Aug 2018 8:41pm
gg2201
So far issues:
Intake manifold hose failure (old hose design) replaced all four.
Oil seals on the back of the oil cooler cheap and easy fix
Currently being investigated for possible turbo issue on offside bank and its losing coolant Crying or Very sad
On the upside it is under warranty Bow down 2011 4.4 TDV8 Autobiography
Post #487592 30th Aug 2018 8:58pm
Kit
I've read about a similar coolant issue, it was the water cooled EGR leaking water into the intercooler, caused turbo failure
Post #489034 16th Sep 2018 6:00pm
Baltic Blue
http://www.fullfatrr.com/forum/topic48509.html
I have added this link because several members have reported failures in the last month, including mine which started to leak
Thanks to JCW for repair tip.
Post #491315 7th Oct 2018 4:01pm
