![]() | Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Mike just adding this from Salter121, he bought a dead 2011 TDV8 and reported:
His full story of re-engining a 4.4TDV8 is here: http://www.fullfatrr.com/forum/topic47799.html Turbos failing on the 4.4 are rare but I guess possible. This possible turbo failure on an L405 4.4TDV8 is also one to watch: http://www.fullfatrr.com/forum/post492232.html#492232 . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Using poly bushes on such a nice car just makes me sad. Nothing ruins a comfortable ride like poly-bushes.
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 ![]() ![]() ![]() |
2011 4.4 tdv8 ab
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
2011 4.4TDV8 40,000 miles - New starter motor. Fiddly but did it myself
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Replace EGR cooler @ 113000kms.50% goodwill from JLR towards cost!! |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
Second starter replaced after another two years... so its about 26 months of life you can get out of those.
The Denso starter motor doesn't lend itself to having the solenoid taken apart to get at the blackened contacts. You have to carefully snip out a welded contact on the outside of the solenoid housing and slide the top off without damaging the connections inside. I looked around for spares and found them for every Denso motor except this one. Just cleaned up the existing ones and put it back together.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
When my starter motor was replaced (2012 WM) there was a credit/recharge on the bill. I asked what that was about and was told that LR get the starter motors back and refurbish them. The value of the defective motor is credited against the cost of the replacement. So depending on where the work is done there may be less value in keeping the old motor and trying to refurbish it yourself. Only Range Rovers since 1988 |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Is anyone keeping records still?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Arbuckle,
BB,was there not talk to publish a list of the range for live values for the values that can be selected?I for one would like to see the live value for engine temp-crusing and then when towing.Charging rate is another one that interest me.
Frans@Yamorna,
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Hi, Arbuckle
Thanks BB!!Great.
