Home > Maintenance & Mods (L322) > Turbo drain mod
Page 3 of 5 <12345>
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I already did! BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #492434 15th Oct 2018 6:19pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Might be worth keeping matters in context - an awful lot of smoke comes from the smallest amount of oil.
Fire up number two Virgil - every trip! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #492437 15th Oct 2018 7:09pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Baltic Blue wrote:
It may be just worth you keeping a close eye on the engine oil level
Mike.
Exactly my point.
Other thing to consider is the amount of burnt oil that the dpf does catch and the subsequent affect that has on loading the dpf.
The problem is the turbo when worked doesn't drain its lubrication quick enough, hence the mod.
Thrash it to burn it off regularly is not really an engineering solution. It may work in that you don't get large plumes of smoke, just smaller plumes more often and greater work load on dpf plus oil consumption. Cheers
James
Post #492438 15th Oct 2018 7:11pm
AJGalaxy2012
From watching the soot load whilst reducing rear visibility to zero, it doesn't seem to affect the DPF, i must admit im surprised but it doesn't. BMW i3 Electric Car
Post #492489 16th Oct 2018 4:58am
JST
^^^ complete opposite to mine, soot load through the roof under heavy work prior to mod being done. Cheers
James
Post #492524 16th Oct 2018 1:27pm
AJGalaxy2012
How odd, i did worry about the DPF but it seems to happily cycle between 10% or thereabouts and 27% (or is it grams, I cant remember the units). I did a live trace on IID when I knew I could make it smoke and I absolutely nailed it, absolutely loads of smoke I couldnt see the road behind me and I kept it nailed, the DPF did go up slightly, about 1/2% of g but I assume that was the diesel burn rather than the oil. I tried it again from a standing start almost immediately, no smoke but the same tiny rise in DPF. BMW i3 Electric Car
Post #492571 16th Oct 2018 5:56pm
JST
It's grams I believe. Isint forced Regan at 28g? So it added 10% 2g after one bootfull..... I would say that's alot Cheers
James
Post #492614 16th Oct 2018 10:25pm
GGDR
Background Regen will be triggered at 17g. Yellow light comes on at 23g
. Cheers, Greg
Post #492631 17th Oct 2018 7:21am
JST
Thank you, i thought it was forced at 28, failure at 30? Background as you say at lower rate. Since modmines runs around 7~10g whenever I check it, which coincidently must be soon after ravens. Cheers
James
Post #492634 17th Oct 2018 8:23am
gg2201
Must admit mine has never once done this but Cornwall is bloody hilly so you can't help go above 2500rpm Laughing 2011 4.4 TDV8 Autobiography
Post #493068 20th Oct 2018 10:28pm
AJGalaxy2012
Some photographs of the Green Oval Garage work being done, not a job to do on your drive!
 BMW i3 Electric Car
Post #493825 28th Oct 2018 6:10am
GraemeS
Australia
A picture showing the drill bit in the top hole could be a little worrying!
Post #493830 28th Oct 2018 9:26am
Out of interest what did green oval charge? There is nothing that can't be fixed with a hammer😜😜
Post #493831 28th Oct 2018 9:29am
AJGalaxy2012
£900 + VAT BMW i3 Electric Car
Post #493840 28th Oct 2018 10:09am
Thud Thud
I shall just continue driving fast.... There is nothing that can't be fixed with a hammer😜😜
Post #493844 28th Oct 2018 10:33am
Page 3 of 5 <12345>
