Home > Maintenance & Mods (L322) > Turbo drain mod
Page 2 of 5 <12345>
AJGalaxy2012
Well mine isnt pretty when it's smoking, I was told a good independent would charge circa £1000 to do it, I havent managed to find one yet that will do it. Duckworths quoted £2500, crazy money. If anyone could recommend a good independent Id appreciate it, I am willing to travel and stay overnight if needs be. Id like to find someone thats done it before so they know whats involved etc. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #492275 14th Oct 2018 4:57pm
Baltic Blue
Give site sponsors Green Oval a ring, (They are in Leeds).
Someone on here had theirs done there, but sorry, I can’t remember who.
Post #492276 14th Oct 2018 5:02pm
mjdronfield
Sheffield Prestige who I use have done it, but they did say it’s an awful job,....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #492277 14th Oct 2018 5:03pm
AJGalaxy2012
Thanks guys I'll give them a call in the week. BMW i3 Electric Car
Post #492278 14th Oct 2018 5:05pm
GGDR
We need a group buy!
Can you pls post up any quotes you get AJG?
Another member I was chatting to about this mentioned Erme Valley Motors, South Devon.
EDIT: just found it. The member was James (username JST):
Quote:
just had the mod done, �200 parts, �450 labour plus the initial diagnostic! local dealer wanted �1500 for same work.
Worth a call esp. if you're willing to stay overnight somewhere.
. Cheers, Greg
Post #492280 14th Oct 2018 5:20pm
AJGalaxy2012
That seems a good price and definitely one I'd pay, I feel a caravan trip coming up!
I'll collate the quotes and I'll add them all to this post. BMW i3 Electric Car
Post #492297 14th Oct 2018 6:46pm
GGDR
Here's the thread it came from: http://www.fullfatrr.com/forum/post438096.html
March 2017 so fingers crossed it's still accurate.
. Cheers, Greg
Post #492298 14th Oct 2018 6:52pm
GraemeS
Australia
stan wrote:
the tsb is in the wiki...
Note that the Wiki only has the original TSB which was only for L322 whereas V3 listed L405 VINs. However I lost the V3 that I had. I also see that V4 has the same release date as V3 , being 23/9/14.
Post #492337 14th Oct 2018 10:00pm
cass
Team Valley Landrover in Newcastle did mine for pennies over £1000 but that was 2 years ago now.
They seem to have done a good job and I can’t imagine the price should be too different now
Post #492353 15th Oct 2018 12:42am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Mine never seemed to suffer from this issue until a couple of weeks ago when I accelerated sharpish to join a dual carriageway on a short slip road. Blimey. It was like something out of a James Bond film! Massive amounts of smoke!
Weirdly, I do the same manoeuvre daily and it's not done it before or since. Not sure quite what to make of it!
It has just been serviced though... 2010 4.4 TDV8 Vogue SE
Post #492360 15th Oct 2018 7:58am
AJGalaxy2012
If you do it daily it will keep it clear, was your driving habit the day(s) before different in any way? BMW i3 Electric Car
Post #492370 15th Oct 2018 9:46am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i can understand the whole drive it above 2500rpm daily to stop the oil build up as that way the oil is being burnt off in insignificant amounts and probably not noticeable. but where is the oil its burning coming from..... Cheers
James
Post #492375 15th Oct 2018 10:04am
Baltic Blue
It may be just worth you keeping a close eye on the engine oil level.
Last time I serviced mine I accidentally put 1/2 a cup full too much oil in when I re-filled it.
It is so easy to put too much in because of the change in reading between cold oil and hot oil.
It should read at least one full section from max when the oil is cold, or it will say “overfilled” when it gets hot.
Post #492376 15th Oct 2018 10:05am
AJGalaxy2012
Booked into Green Oval, they were very responsive, they agreed it sounded like the problem, 24th it goes in, they said 2 days just be safe because its a 7hr + job.
I will collate the prices later. BMW i3 Electric Car
Post #492428 15th Oct 2018 5:49pm
Baltic Blue
Thumbs Up Thumbs Up
Don’t forget to tell them you found them on the forum.
Even if they don’t do a bit of discount, it will encourage them to continue their sponsorship.
Post #492430 15th Oct 2018 6:01pm
Page 2 of 5 <12345>
