Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel.
Page 1 of 3 123>
A quick heads up for all the 405 owners out there. I have found a water leak on my 2013/14 L405 AB and unusually its from in front of the UK drivers side REAR wheel! Im guessing they run to rear passengers heating? Maybe?
The black metal thing in these pics is the fuel tank protector.
Removing the very rusty metal securing tab/bracket, then the rubber coating i found it was leaking from a pinhole size hole/maybe a crack, maybe from the rusty bracket? 10mm away from the end where the rubber pipe/hose connects... JLR MD wanted nearly a grand to remove the rear subframe/cradle and replace (just that 18" aluminium pipe) Shocked Sniggering Thud
So, i simply replaced the rubber pipe/hose (on the right in the pics) with a piece 30mm longer and cut the ali pipe back 20mm so beyond the crack/pinhole and fitted the new/longer rubber pipe/hose... Happy days, no more leak!
Post #492114 13th Oct 2018 1:51pm
For anyone following "MY NEW CAR" thread? Yes i have JLR warranty and for some reason "beyond my understanding" the warranty refused to replace this pipe! Shocked Rolling Eyes Yawn Worryingly the JLR MD's were happy for me to collect my car and drive the car away loosing coolant (quite rapidly too)
I have however complained to JLR CC so we will see what comes of that?
Post #492116 13th Oct 2018 2:09pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I cannot understand what your moaning about
https://media.landrover.com/en-gb/news/201...ar-award-0
Rolling with laughter David
Please let me know if my comments upset you, I may wish to upset you again.
Post #492120 13th Oct 2018 4:25pm
Me moan sir Whistle Rolling Eyes Big Cry Rolling with laughter
Post #492154 13th Oct 2018 8:03pm
AMD
I’m told the Land Rover Approved Used warranty only covers ‘sudden’ mechanical failure. Corrosion is not not considered a sudden failure. This may be the same for other manufactures too, but I find it difficult to accept that on a £100k off road vehicle this level of corrosion exists after 4 years. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #492186 14th Oct 2018 7:25am
Yet they Okay'd the replacement of the front suspension struts/air springs without question? Cost wise, I'm very glad they did, obviously! But i cannot understand it...
Post #492210 14th Oct 2018 10:56am
AMD
Agreed, there is no consistency.
I’ve decided to sell my L405, I intended to purchase a newer MY17 FFRR, but now moving away from the brand. Such a shame but I am not happy with their after sales and never felt a valued customer. Current MY2020
Post #492216 14th Oct 2018 11:22am
randomusername
What you need to do is to find a local indy specialist that can fix all these little niggles for you...
I'm sure there must be someone close to you?
Whistle
Post #492331 14th Oct 2018 8:26pm
TJH1985
I think I have seen this mentioned elsewhere also but ours has also sprung the same leak.. future common issue?
We have been chasing down a mystery coolant leak for some time, passed a overnight pressure test at the dealership etc. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #593513 7th May 2021 5:05pm
I think you may have found the issue there.
There are a few LR specialists round here, infield4x4 are one down near Coalville who may be able to help. There is nothing that can't be fixed with a hammer😜😜
Post #593610 8th May 2021 1:35pm
TJH1985
It’s been done Thumbs Up
Post #593612 8th May 2021 2:10pm
Looks like they replaced the pipe?
Post #593629 8th May 2021 6:07pm
TJH1985
It’s under Approved Used so went into the main dealer for the work, usually I’d just have used a piece of pipe myself.
Notice what’s missing from the new pipe… Rolling Eyes
Rear diff was leaking from the pinion seal, so they had that out as well. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #593634 8th May 2021 6:20pm
That was going to be my next statement! They left off the offending clip!
But how is it now secured to the car?
Post #593639 8th May 2021 6:46pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
The pipe without the clip looks like it’s just a sheath? it’s a different diameter to the ally pipe. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #593641 8th May 2021 6:53pm
Page 1 of 3 123>
