Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
For anyone following "MY NEW CAR" thread? Yes i have JLR warranty and for some reason "beyond my understanding" the warranty refused to replace this pipe! Worryingly the JLR MD's were happy for me to collect my car and drive the car away loosing coolant (quite rapidly too)
13th Oct 2018 3:09pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
I cannot understand what your moaning about
13th Oct 2018 5:25pm |
Me moan sir |
13th Oct 2018 9:03pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
I’m told the Land Rover Approved Used warranty only covers ‘sudden’ mechanical failure. Corrosion is not not considered a sudden failure. This may be the same for other manufactures too, but I find it difficult to accept that on a £100k off road vehicle this level of corrosion exists after 4 years. Current MY2020
14th Oct 2018 8:25am |
Yet they Okay'd the replacement of the front suspension struts/air springs without question? Cost wise, I'm very glad they did, obviously! But i cannot understand it... |
14th Oct 2018 11:56am |
Agreed, there is no consistency.
14th Oct 2018 12:22pm |
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 |
What you need to do is to find a local indy specialist that can fix all these little niggles for you...
14th Oct 2018 9:26pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
7th May 2021 6:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
I think you may have found the issue there.
8th May 2021 2:35pm |
It’s been done
8th May 2021 3:10pm |
Looks like they replaced the pipe? |
8th May 2021 7:07pm |
It’s under Approved Used so went into the main dealer for the work, usually I’d just have used a piece of pipe myself.
8th May 2021 7:20pm |
That was going to be my next statement! They left off the offending clip!
8th May 2021 7:46pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
The pipe without the clip looks like it’s just a sheath? it’s a different diameter to the ally pipe. 2011 (MY12) 4.4 TDV8 Vogue
8th May 2021 7:53pm |
