![]() | Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel. |
Tommybuk Member Since: 17 Jan 2024 Location: Ellon Posts: 13 ![]() ![]() ![]() |
Hi. I didn't get any pics. I just remember finding the route across fairly obvious.
V9 SVO Member Since: 10 Dec 2023 Location: Cornwall Posts: 2 ![]() ![]() ![]() |
Many thanks |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 80 ![]() ![]() ![]() |
How confident are you in it being 16mm? 😂
2008 TDV8 Vogue SE 2002 TD6 Vogue 2002 Defender 90 TD5 2002 Range Rover P38 Autobiography 2002 Range Rover P38 Westminster Just a sucker for big bills!!! |
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 61 ![]() ![]() ![]() |
My 2018 4.4 with 62K mls has developed this leak, and I assume it’s from same spot as mentioned on this thread. Also found puddle underneath rear driver passenger seat. I’m going to call LR assistance out tomorrow and see if they can get the car into MD quicker and hopefully covered under warranty. Also hoping LR assistance can provide a replacement vehicle while mine is being repaired.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
It is fairly standard size coolant pipe. I replace mine a while back running from just behind the front wheel under the sill back to the rear left pipes in the wheel well area.
