Home > Maintenance & Mods (L322) > 4.4 TDV8 new battery
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Folks,
Fitted a new battery this evening, what a caper, I'd read somewhere that the Yuasa 020 at Halfords fitted in the tray, and being £7 cheaper than the 019 guess which one I went for......
I can tell you an 020 won't fit in a 2011 4.4 TDV8!
The 019 does fit nicely though
3 hours of life later, happy Range Rover, even happier owner Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491492 8th Oct 2018 8:34pm
GGDR
I am sure I've read it can be done but the bottom 'lugs' need trimming off.
. Cheers, Greg
Post #491501 8th Oct 2018 9:07pm
GGDR
Also I do think AGM is recommended, which 019 did you get?
. Cheers, Greg
Post #491502 8th Oct 2018 9:09pm
Ah the battery swapping joys.....
There is also something about telling the charging system that it has a new battery, and yes, it should be AGM. There is nothing that can't be fixed with a hammer😜😜
Post #491503 8th Oct 2018 9:31pm
Bushy30
https://www.halfords.com/motoring/bulbs-bl...tsid:94971|cid:1034356518|agid:51236243896| Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491506 8th Oct 2018 9:33pm
Bushy30
Still wouldn't work with the lugs off, there's no room for the +ve terminal connector!!!
Tell the car it has a new battery? How do you do that?
Cheers Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491509 8th Oct 2018 9:36pm
Bushy30
The 019 is the one suggested by the Halfords website, complete with 5 year warranty.
Can't say fairer than that I reckon! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491517 8th Oct 2018 10:00pm
mjdronfield
Think you need a diagnostic tool or a friendly garage. Charging system needs to do different things I believe or battery life will be substantially shortened.
If you put agm charging or similar in to google might have more info.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #491521 8th Oct 2018 10:29pm
Bushy30
Will reset it in the morning, thanks all for pointing it out Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491522 8th Oct 2018 10:30pm
GGDR
Bushy that link you posted isn't AGM....
AGM 019 is here: https://www.halfords.com/motoring/bulbs-bl...-guarantee
I'm not suggesting the above is the best 019 AGM, just to show you - might be worth a conversation with Halfords if they offered up the other one, it doesn't meet your MY2011 spec.
. Cheers, Greg
Post #491526 9th Oct 2018 5:49am
Baltic Blue
I swapped mine for one of these a couple of months ago and , touch wood, it seems OK.
Free next day delivery.
Post #491537 9th Oct 2018 7:35am
bit cheaper than the £226 JLR battery i 'had' to get when my westie wouldnt start on the first day of my holiday .. Twisted Evil
Post #491538 9th Oct 2018 7:45am
Baltic Blue
Stan,
Did you get a 5yr Warranty with JLR ?
That was why I opted for this one.
Post #491546 9th Oct 2018 8:09am
Bushy30
Thanks for all the input chaps -- now I'm happy to be shot down, but with a 5 year guarantee and the fact that the Yuasa was the one they suggested when I entered my 'reg' will this not be OK -- I mean it's a battery, not likely to die over night, and if it begins to fail I'm likely to notice? My, I suspect original, battery as fitted gave me about 3 weeks notice it wasn't happy................. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491547 9th Oct 2018 8:14am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
It'll be OK. I've had the same Yuasa 019 fitted for the past year and it's been fine.
Post #491555 9th Oct 2018 10:07am
