Home > Maintenance & Mods (L322) > 4.4 TDV8 new battery |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Thanks Gyre8 -- we have very different vehicles though!
9th Oct 2018 10:23am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35253 |
Mike, i recall parts man saying its a 2year warranty...this was an emergency 'must have' purchase and of course i would have gone cheaper if i had the time.. |
9th Oct 2018 10:24am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3762 |
I fully understand Stan,
9th Oct 2018 11:14am |
indeed Mike, many euros... |
9th Oct 2018 11:57am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2463 |
It appears that setting the battery to a new battery causes battery management to not pussy-foot around with light charging that it considers necessary with an old battery to avoid boiling. The corollary is that if the battery, especially an AGM, is recorded as a new battery on a regular basis then the battery will last a lot longer. A Varta 019 AGM that I fitted to my then 3.0 D4 (now owned by my son) lasted only 3 years, requiring more and more use of a battery charger even though frequent long drives occurred, in similar fashion to the original battery which also only lasted 3 years. The battery was replaced with another Varta 019 AGM which mechanically failed around 3 months later. The earlier Varta, which had been put to use elsewhere with solar panels attached, was refitted to the D4 while waiting for a replacement of the failed one as none were in the country and the next shipment was a while off. The D4 was again informed of the new battery as a charger had been required daily for the mechanically-failed one and now, many months later including through winter the temporarily refitted battery has performed perfectly. The new replacement waits patiently to be used, with an occasional top-up with a charger. |
9th Oct 2018 8:02pm |
Thanks Graeme, gives me some hope Current: 2011 FFRR Vogue SE 4.4 TDV8
9th Oct 2018 8:06pm |
