Home > Maintenance & Mods (L322) > 4.4 TDV8 new battery |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Hi Folks,
8th Oct 2018 9:34pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3527 |
Also I do think AGM is recommended, which 019 did you get?
8th Oct 2018 10:09pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Ah the battery swapping joys.....
8th Oct 2018 10:31pm |
https://www.halfords.com/motoring/bulbs-bl...tsid:94971|cid:1034356518|agid:51236243896| Current: 2011 FFRR Vogue SE 4.4 TDV8
8th Oct 2018 10:33pm |
Still wouldn't work with the lugs off, there's no room for the +ve terminal connector!!!
8th Oct 2018 10:36pm |
The 019 is the one suggested by the Halfords website, complete with 5 year warranty.
8th Oct 2018 11:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7719 |
Think you need a diagnostic tool or a friendly garage. Charging system needs to do different things I believe or battery life will be substantially shortened.
8th Oct 2018 11:29pm |
Will reset it in the morning, thanks all for pointing it out Current: 2011 FFRR Vogue SE 4.4 TDV8
8th Oct 2018 11:30pm |
Bushy that link you posted isn't AGM....
9th Oct 2018 6:49am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3743 |
I swapped mine for one of these a couple of months ago and , touch wood, it seems OK.
9th Oct 2018 8:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35120 |
bit cheaper than the £226 JLR battery i 'had' to get when my westie wouldnt start on the first day of my holiday .. |
9th Oct 2018 8:45am |
Stan,
9th Oct 2018 9:09am |
Thanks for all the input chaps -- now I'm happy to be shot down, but with a 5 year guarantee and the fact that the Yuasa was the one they suggested when I entered my 'reg' will this not be OK -- I mean it's a battery, not likely to die over night, and if it begins to fail I'm likely to notice? My, I suspect original, battery as fitted gave me about 3 weeks notice it wasn't happy................. Current: 2011 FFRR Vogue SE 4.4 TDV8
9th Oct 2018 9:14am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 254 |
It'll be OK. I've had the same Yuasa 019 fitted for the past year and it's been fine. |
9th Oct 2018 11:07am |
