Home > Maintenance & Mods (L322) > Rear Wheel Arch Rust Repair ?
Page 4 of 4 <1234
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
don't worry, fill it with grease it'll be fine... once you find time to do it that is.
I've had the trim bits in my shed for over a year now and not got around to do the bloody job yet! Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #487975 4th Sep 2018 1:17pm
DrRob
Resurrecting an old thread....
Mark - how many of these VLR001623 strips do you need to do both rear wheel arches? I’m getting confused even after reading thread over and over Big Cry
Is it 4 to do both rear arches with only one join or 4 to do all arches front and back?
Sorry for being thick Big Cry Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530711 13th Oct 2019 8:53am
mjdronfield
Hi mate,
You don’t need any protectors on the front as the front wings are aluminium so don’t rust.
You need 4 to do the rears if you don’t want a join. You can’t run all the way round in 1 go. Have a look at your rear arch and you will see what I mean.
The dealer has them in different lengths, so it may be if you got a longer strip, you could manage with 2, but I didn’t go through doing that.
Some have recommended plastic door edge strips off eBay, and in hindsight that might be an option as my strips have been on 3 years and they are out of shape and need replacing again really.
That make sense? Thumbs Up 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #530755 13th Oct 2019 3:31pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530761 13th Oct 2019 4:15pm
GGDR
Have just posted this on another thread:
I really wanted one continuous strip front to back so I bought something similar to the ebay link in rubber.
https://www.ebay.co.uk/itm/Car-Door-Guard-...27cac56ea1
Problem was if you run it around the lip when you get to the at the 12 o'clock position there is a kink in the lip and I could not get the rubber edge to conform.
So never fitted it. On the 'to do list' though.
If you could fit a plastic something that could be heated to adapt to the kink it would be an ideal solution
How did others deal with the kink? Cheers, Greg
Post #530781 13th Oct 2019 6:58pm
DrRob
Greg
I used LR strips on trailing lip and the eBay sourced plastic trims on leading lip edge Thumbs Up
Lots of grease used Rolling with laughter
https://www.fullfatrr.com/forum/post536103.html#536103 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #536104 1st Dec 2019 8:39pm
Page 4 of 4 <1234
