Home > Technical (L322) > burning smell
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
burning smell
hello gents i am hoping someone can help with a new problem that has come up , when i put my foot down i get a nasty burning smell and some lack in throttle if i put it in sport mode i get very little throttle,a burning smell and a noise from the underside . when driving in a relaxed way there is no problem ... my first thought is the clutch
Post #486186 15th Aug 2018 5:01pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Can you narriw it diwn a but, What sort of burning smell ?
Plastic, ferodo (brakes/clutch), oil, rubber ? Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #486235 15th Aug 2018 10:26pm
Harlin
more like a clutch but not like a slipping clutch
Post #486237 15th Aug 2018 11:09pm
cass
Brakes binding?
Post #486248 16th Aug 2018 7:20am
Harlin
not brakes Exclamation
Post #486311 16th Aug 2018 8:28pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Alternator smells a bit burny when it's on it's way out!
Post #486362 17th Aug 2018 10:42am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Supercharger drive belt?? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #486399 17th Aug 2018 6:06pm
Unless you have a very rare fattie indeed there is no clutch as it’s automatic.
Could be an oil leak onto the exhaust and the extra heat from nailing it has caused the smell. There is nothing that can't be fixed with a hammer😜😜
Post #486456 18th Aug 2018 10:02am
John w
I would be inclined to go for a drive to get it to happen, stick it on max height, and have a crawl and sniff, see if you can narrow it down that way to at least a general location.
Does it change gear OK ?
One other thought, if it's a 3.6 turbo could it be the variable vane actuators ?
No idea if you can get to it, but would be worth checking the linkage moves OK.
Sorry, not sure what age / engine you have. Too many toys, not enough time
Post #486460 18th Aug 2018 11:42am
Harlin
its a 06 , 4.2 sc its not just the smell i also lose power with a clater sort of noise which is much worse if i put it into sport mode ,could it be the cat . i am not sure if the cat would smell when i put my foot down but the sound seems to be from that area , cheers rob
Post #486857 22nd Aug 2018 6:34pm
John w
Since it is Supercharged I would therefore suggest you have a good look at the drive belt.
Aside from that you need to get it to smell, immediately stop and do the sniff test.
It could be something touching the exhaust under heavy load like the lambda sensor wiring (could alter the fueling).
Main concern would be the gearbox Crying or Very sad
It sounds like your going to have fun finding this Neutral Too many toys, not enough time
Post #486876 22nd Aug 2018 9:45pm
holidaychicken
Clattery noise , lack of power and burning smell are not good combinations but I would expect some codes if transmission related.
I think I had blocked cats and it felt like I had excessive engine braking and a general feeling of holding back.
Post #486877 22nd Aug 2018 10:05pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Suggest you Get it to a garage for accurate diagnosis before it becomes undriveable ... it ain’t going to improve 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #486878 22nd Aug 2018 10:17pm
Harlin
no codes on transmission so hoping its the cat (cheapest option)
Post #486928 23rd Aug 2018 4:34pm
Harlin
its the cat
Post #488302 7th Sep 2018 5:40pm
