![]() | Home > Technical (L322) > burning smell |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Can you narriw it diwn a but, What sort of burning smell ?
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
more like a clutch but not like a slipping clutch |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 752 ![]() ![]() |
Brakes binding? |
not brakes |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Alternator smells a bit burny when it's on it's way out! |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Supercharger drive belt?? Regards,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Unless you have a very rare fattie indeed there is no clutch as it’s automatic.
I would be inclined to go for a drive to get it to happen, stick it on max height, and have a crawl and sniff, see if you can narrow it down that way to at least a general location.
its a 06 , 4.2 sc its not just the smell i also lose power with a clater sort of noise which is much worse if i put it into sport mode ,could it be the cat . i am not sure if the cat would smell when i put my foot down but the sound seems to be from that area , cheers rob |
Since it is Supercharged I would therefore suggest you have a good look at the drive belt.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Clattery noise , lack of power and burning smell are not good combinations but I would expect some codes if transmission related.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
Suggest you Get it to a garage for accurate diagnosis before it becomes undriveable ... it ain’t going to improve 4.2 SC - sold , now bought back
no codes on transmission so hoping its the cat (cheapest option) |
its the cat |
