![]() | Home > Technical (L322) > Delayed Air Con |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7896 ![]() ![]() ![]() |
That’s a cracking result then. Another known issue....
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Well done! Glad I got someone else to do mine though! 2010 4.4 TDV8 Vogue SE |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Nino,
This is why I couldn't do it in the garage...
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
John w, is that 350 YZ ?
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
This should go into Wiki RR L322 TDV8 4.4 SE 2019 to present
Just got around to doing this job ………….. it's very challenging access ………….. but doable. I wouldn't want to do it again!
What do you mean, you wouldn’t want to do it again?
Having had the whole compressor replaced a year ago, supposedly with the new improved valve, mine has started exhibiting the same symptoms again. Just had it back in to the indy that replaced it and it is indeed the compressor assembly (presumably the valve).
Wow, so they don’t work for that long once fixed. |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 ![]() ![]() ![]() |
It's so discouraging. I'll have to pull my service history but I recall the previous owner had the compressor in mine replaced, too. 2012 Range Rover Autobiography
Would you be able to find out which brand compressor was used when you last replaced it? 2012 Range Rover Autobiography 91 BMW 850i 6 speed 94 BMW 850 CSi 6speed Supercharged Tbirds Audi S8, Audi V8 Quattro |
I can ask, but it was just the genuine LR one. 2010 4.4 TDV8 Vogue SE |
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
I have just replaced the valve on mine.
