![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Item 4. It screws into the pipe leading from the EGR valve as the pipe heads towards the front.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Greg,
Mike.
Greg,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Sounds like you're doing some excellent chauffeur work there Mike. Def deserves a cold beer.
Greg,
Yes - thanks Mike. And in the picture I posted it's No.4 and the same sensor in the pic you posted it's No. 5 .
Greg,
Ah thank you Mike for checking the TSB's! Shame nothing there...
Greg,
Hi again guys,
Two sensors are located in the right exhaust pipe on Euro5 engines. The top one close to the manifold is labelled as an oxygen sensor and the lower one close to the cat is just labelled a sensor WDN500130 in 2012 Microcat but google shows as an EGT sensor.
Graeme, you're a gent! That's extremely helpful!
Greg,
