Home > Technical (L322) > Air Susp. Inactiv, no lights on the console
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi,
My L322 air suspension is playing up. The car holds height and after clearing code the suspension returned and worked fine. about a week later the same error appears again.
This time the AA man's ID Tool read the fault as
"118 Air suspension pressure accumulator Pressure drop on filling"
Once he cleared the code the air suspension worked. I raised her to off road mode and she held, dropped it down low and raised it back up again. No sound of air escaping from the bags.
Any suggestions?
Post #483020 9th Jul 2018 6:50pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Maybe a leak in the reservoir? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #483025 9th Jul 2018 7:31pm
compressor exhaust filter clogged up?? ... - .- -.
Post #483029 9th Jul 2018 7:48pm
Teaspoonasaurous
Hi Stan,
That sounds like a good problem (ie one I could fix) how would I check that?
Post #483030 9th Jul 2018 7:56pm
this relates to the suspension being stuck in off road height but it can also possibly be your problem,
http://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #483032 9th Jul 2018 8:02pm
What is your reservoir pressure like?
Check regularly if you have the kit to test it. .
Post #483038 9th Jul 2018 8:41pm
Teaspoonasaurous
I'm getting a tool at the weekend so that I can monitor it and try and figure it out.
Post #483041 9th Jul 2018 8:53pm
Sandy Choda
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I'm struggling with the same fault. Mine's stuck in Off Road height with system shut off after having burst a front airbag... The good news is that it's holding its height now
Is there anyone in/around West Mids with IID tool that can help me with re-calibration?
Post #483078 10th Jul 2018 9:34am
are your air bags ok now???
if so try the info in my link or a battery reset.. ... - .- -.
Post #483080 10th Jul 2018 10:53am
Sandy Choda
We were trying to check the suspension so went to Off road height and the bag burst. I then replaced the air bag but on standard height on the control panel the car is still sitting at off road height. After a short drive the system has read abnormal heights and gone into hard fault shut down.
Post #483081 10th Jul 2018 11:04am
Teaspoonasaurous
Update: following the code clear yesterday the car has been perfect. I did about 130 miles today and it slipped seamlessly in and out of motorway mode. I had to put it to access mode in a multi-storey car park and it managed that no problems.
Hopefully all is good now!
Post #483129 10th Jul 2018 7:44pm
Teaspoonasaurous
Hmm this error has reappeared after two months of perfect driving. Cleared but it seems to be reappearing instantly I’ll have to investigate further tomorrow
Post #487068 24th Aug 2018 10:45pm
Teaspoonasaurous
Post #487069 24th Aug 2018 10:46pm
Air bag on the other side, or other axle ?
Other options: height sensors, compressor, reservoir, valves, pipes Embarassed .
Post #487072 24th Aug 2018 11:36pm
Teaspoonasaurous
Airbags seem fine as it is maintaining pressure. I think it’s a reservoir issue.
Post #487081 25th Aug 2018 6:18am
