Home > Technical (L322) > Air Susp. Inactiv, no lights on the console |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Maybe a leak in the reservoir? 2015 4.4 AB
9th Jul 2018 7:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
compressor exhaust filter clogged up?? ... - .- -.
9th Jul 2018 7:48pm |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 |
Hi Stan,
9th Jul 2018 7:56pm |
this relates to the suspension being stuck in off road height but it can also possibly be your problem,
9th Jul 2018 8:02pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
What is your reservoir pressure like?
9th Jul 2018 8:41pm |
I'm getting a tool at the weekend so that I can monitor it and try and figure it out. |
9th Jul 2018 8:53pm |
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 |
I'm struggling with the same fault. Mine's stuck in Off Road height with system shut off after having burst a front airbag... The good news is that it's holding its height now
10th Jul 2018 9:34am |
are your air bags ok now???
10th Jul 2018 10:53am |
We were trying to check the suspension so went to Off road height and the bag burst. I then replaced the air bag but on standard height on the control panel the car is still sitting at off road height. After a short drive the system has read abnormal heights and gone into hard fault shut down.
10th Jul 2018 11:04am |
Update: following the code clear yesterday the car has been perfect. I did about 130 miles today and it slipped seamlessly in and out of motorway mode. I had to put it to access mode in a multi-storey car park and it managed that no problems.
10th Jul 2018 7:44pm |
Hmm this error has reappeared after two months of perfect driving. Cleared but it seems to be reappearing instantly I’ll have to investigate further tomorrow |
24th Aug 2018 10:45pm |
24th Aug 2018 10:46pm |
Air bag on the other side, or other axle ?
24th Aug 2018 11:36pm |
Airbags seem fine as it is maintaining pressure. I think it’s a reservoir issue. |
25th Aug 2018 6:18am |
